Join Airstream Forums Today
Old 12-04-2011, 05:43 PM   #15
Mr & Mrs S's Avatar
Newton , Texas
Originally Posted by casa3805 View Post
Joshua,
I went to the site you pm'd me and then checked measurements against the old ones that came out. I think those will be too big for you. But the ones posted right above this look good. Especially if they are now a sealed kit. Not sure about the plug on the end of the wires, I had nothing like that behind mine, it was wire to wire splice.
Here are the pics with my old ones so you can check measurements. Depth was fine, but I think the lights were simply bigger.
Thanks Casa for your help, you are correct the lights I was looking at are to big.
But I ordered the above mentioned sealed kit from Dan's LED4RV.
So Im good to go! Ill report back around Xmas when I get home and there installed. Looking forward to seeing the difference.
MR. & MRS. S
--Streamin & Gleamin--
Airstreamless, but havent lost our passion for them. Currently looking for the next project!
Mr & Mrs S is offline   Reply With Quote
Old 12-20-2011, 05:38 AM   #16
1987 25' Sovereign
Punta Gorda , Florida
Pics! We "require" pics when you are done. You will hate yourself if you do not do before, during, and after shots. I always have good intentions, but then get busy with the job and forget that the "during" pics are worth bunches to people down the line!
Enjoy the fun.
Got the kit from LED4RV Dan his site has pick's tht leave nothing to be desired. Only thing I did was goop the spacer to the lens before I installed it to make a gasket otherwise they take about 10 minutes to install & they are super!
erikk is offline   Reply With Quote
Old 12-20-2011, 07:13 PM   #17
CASA3805
casa3805's Avatar
1984 27' Sovereign
Corpus Christi , Texas
Images: 30
Nice...gotta agree, that is where I got all the clearance lights.
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
LED tail lights beerrun'r Lights - Interior & Exterior 12 01-13-2012 12:29 PM
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 3 07-04-2011 07:44 AM
LED interior lights: A complaint hampstead38 Lights - Interior & Exterior 0 03-23-2011 08:38 AM
LED Lights on 87 345 rear tail/turn Myrtle lynn Classic Motorhomes 19 02-28-2011 09:43 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
