Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1987 Sovereign
Old 11-22-2002, 12:54 PM   #1
tomb
tomb's Avatar
Profile:
Images: 8
hot water heater bypass
anyone had a ploblem with there factory installed bypass? small square box inside side door at water heater, mine was leaking and when I went to winterise it sent antifreeze to the water heater with it in the bypass mode....can it be bought or is there a good fix ???? thanks Tom
TOM BOONE 1987 SOVEREIGN 25' WBCCI#14120
tomb is offline   Reply With Quote
Old 11-22-2002, 01:04 PM   #2
Gordon Watt
Gordon Watt's Avatar
Profile:
The bypass one my heater was leaking and I found the bottom end of the pipe was too tight and squashed the washer which is quite thick and got distorted.
Your friendly RV person should have some for you. My dealer didn't charge me for it.
Be careful installing it as they are thick and should not be tightened too much or they will leak and/or restrict water flow.
Gordon Watt is offline   Reply With Quote
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
Nobody needs a hot water heater!!! Rick Alston Off Topic Forum 109 02-13-2004 09:52 PM
Water heater bypass installation Craig Water Heaters, Filters & Pumps 4 04-05-2003 04:13 PM
Lighting Hot Water Heater hhuber Water Heaters, Filters & Pumps 14 04-01-2003 09:31 AM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
