Old 06-07-2011, 04:10 PM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
What A/C did you install?
Trying to decide on a replacement and wanting to see what others have done.
adwriter73 is offline   Reply With Quote
Old 06-07-2011, 04:44 PM   #2
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Carrier low profile, not sure if they are available anymore.
SilverHoot is offline   Reply With Quote
Old 06-07-2011, 04:48 PM   #3
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Coleman 13,500 BTU - works great! My Safari is only 22' perhaps you would want to consider a 15,000 BTU.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 06-07-2011, 05:36 PM   #4
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Yes, I think I want the 15K BTU
Old 06-07-2011, 07:23 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
When I replaced ours, I went with a Penguin 13,500 with a heat strip. Now, you can't get the 15k Penguin, and the only way to get heat is a heat pump. They work well, and are efficient, but are pricier than a regular a/c unit.
So, long story short, if you want 15k, you are limited to Brisk Air or AirXcell (formerly Coleman). Both drain water over the side of the trailer, which is the other reason I went with a Penguin, it comes with a drain pan so it won't run down the side of the trailer.
Old 06-07-2011, 07:31 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Terry,
How does that unit stack up against the old Armstrong Baybreeze? And what would it take to mount two of them? Upgrade to 50 amps?
Aaron
WBCCI #XXXX AIR #2495
Old 06-07-2011, 07:35 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Also FWIW Dometic is showing the Penguin in a 15k on their website...slow to update? Or is that the wrong unit?
Aaron
Old 06-07-2011, 07:59 PM   #8
For a Sovereign in Texas, I'd definitely advise the 15K BTU. And even that might only get you -20 degrees, so on a 105 degree day, the best you're going to get might be something like 85 inside the coach. Always park in the shade.
And yes, to run two A/C units you'd need to go up to 50A. At rated load, mine draws something like 14.1A. So two of them would put you almost to your original 30A, and then turning on a light or two would kill the breakers.
Onan install 05 30 Classic GetOutDoors Generators & Solar Power 16 09-10-2012 07:59 AM
Thinking of going Dual A/C Mr & Mrs S Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-04-2011 06:48 AM
A/C Cover...how does it come apart? KyMoonshine Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-10-2011 06:59 PM
A/C Replacement malopezmo Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-12-2011 03:34 PM
A/C pan replacement Airhouse Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-28-2011 08:16 PM
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
