Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1978 Sovereign
Old 01-09-2008, 01:21 PM   #15
84Sovereign's Avatar
Profile:  1984 27' Sovereign
Escondido , California
I completed the same upgrade to our '84 Sovereign last month and also have a question about the "extra" white wire. I now understand that it is for the AC Power light on the control panel. Does it connect to 12v or 120v for the indicator light?
84Sovereign is offline   Reply With Quote
Old 01-09-2008, 01:55 PM   #16
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
If you do a search, I remember there's a post from someone who did a detailed explanation on how to restore the 'power on' light's function. They did do a much better job explaining it than I ever could!
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 01-09-2008, 02:04 PM   #17
You're right! I found my answer here: Installing an Intellipower 9200
Thank you!
Old 01-09-2008, 04:42 PM   #18
WBCCI 11067 WDCU
ckeysor's Avatar
Profile:  1986 25' Sovereign
Atlanta , Georgia
white wire
You are right it is for the AC on light on the control panel. Just an idea for everyone... My wife hated that light on all night so I did not connect it back up. Instead I just bought a circuit plug tester from Home Depot and put it into the outlet behind a set of drapes. Not only can I tell when I am plugged in but I can also tell if the grounding and polarity is right. Believe or not but my 1978 had a light that told me when my polarity was wrong. Since they went through the effort before I figured that was a circumstance that actually happended from time to time.
Chris Keysor
WBCCI 11067
1986 Sovereign 25' CB
2007 Chevy Silverado 1500
2007 Toyota Land Cruiser
ckeysor is offline   Reply With Quote
Old 01-10-2008, 05:56 AM   #19
GA Airstreamer Air_005
Profile:  North , Georgia
thanks for the idea on raising the unit up off the floor. I noticed the screened vent underneath where the univolt sat, for cooling I guess. There is plenty of room in there so I will try your idea.
As for the ac cord it is split so you can power the unit and something else, just not sure how that part works...I might have to take apart the fuse panel to see where it is going. I guess I could power up the intell. and leave that plug off to see what doesn't work. From another thread I just read, maybe it powers my ceiling vent fans..
So the black cables that go to the fuse panel supply the power for the 12v system and then lead to the battery charging cables--right?
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 01-12-2008, 03:41 PM   #20
got the Inteliipwer installed today. Went quite smoothly. The two black cables bugged me so I swapped out the positve for a red one. Sure is weird after listening to the Univolt for 7 years, to have no sound.
Does anyone who has the IP know how powerful the fan is? I did not hear much fan noise if any.
Made sure it has plenty of "breathing" room for circulation around it.
My Music Site:
Pingbacks are On
Mostly good power after Univolt was replaced... ricjones1138 Electrical - Systems, Generators, Batteries & Solar 1 04-10-2006 06:39 AM
Intelli-power jcferguson Electrical - Systems, Generators, Batteries & Solar 11 11-02-2005 06:12 PM
Univolt +/- Inteli-Power = ? krowsea Electrical - Systems, Generators, Batteries & Solar 4 11-14-2004 10:24 AM
Intelli Power 9100 help Jimbo Electrical - Systems, Generators, Batteries & Solar 2 06-28-2004 06:54 PM
Where to buy Intelli power Tin Hut Electrical - Systems, Generators, Batteries & Solar 1 04-14-2004 08:06 PM
SEO by vBSEO 3.1.0
