Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1978 Sovereign
Old 09-15-2006, 08:42 AM   #1
charlie tuna
near ichnetucknee springs
charlie tuna's Avatar
Profile:  1978 31' Sovereign
davie , Florida
repair of rear bathroom sliding doors?
hi all,
we have a 1978 rear bathroom unit and the sliding doors do not want to slide easily. is there any solution to this problem? the one door has a full length mirror on it -- could it be the weight of this mirror causing the problem??
charlie tuna is offline   Reply With Quote
Old 09-27-2006, 11:30 AM   #2
charlie tuna
davie , Florida
answered my own question... this past weekend i was looking at my bathroom sliding door problem --- i should say "none" sliding door as it didn't slide freely. the short side slide was missing it's bottom track and i found it in one of the closets... i drilled some extra holes in it and re-installed it high enough to carry some of the door's weight. it made such a big difference i took a look at the other sliding door's bottom track. it was loose and held in place by only one screw. i held the track up to carry some of the door's weight and had my wife try the door --- it slid easily!! this door is heavy and i decided to cut a block of wood just large enough to fit between the floor and the bottom track. i used an aluminum angle to secure the block to the floor. this cured the problem with both doors. if your doors don't close and open easily -- check out the bottom track support.....
Rear bath mirror! niftypkg General Interior Topics 1 04-10-2007 08:52 PM
rear air suspensiom problems wb13798 Airstream Motorhome Forums 19 03-03-2003 07:12 AM
Moving the Rear Bath Forward? jabra General Interior Topics 2 10-18-2002 05:09 PM
Bent Door Repair Road Ruler Doors & Locks 6 09-02-2002 07:27 PM
Dash Repair Questions JW84345 Airstream Motorhome Forums 10 05-06-2002 10:18 PM
