Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1978 Sovereign
Old 07-26-2003, 04:07 PM   #1
lbf78SvgnInt31
lbf78SvgnInt31's Avatar
Profile:
Question Removing a radio/8 track unit for repair or replacement
The radio/8 track unit built into the living room cabinet of my 1978 31' Sovereign International does not work. I have removed all the screws that hold the facica in which it is mounted. It is loose in the enclosure but I can only move it around about 1/2" to 3/4". There is an 8 track tape storage unit pop riveted to the facica. Can any one tell me how to get this thing the rest of the way out?
I actually would like to replace this with a more modern radio/CD player. Has any one else already made this change? If so, what kind of unit did you select? Was it a "drop-in" replacement?
Also, only one of the two speakers in each end of the trailer appears to be working. Any thoughts on the cause(s) and possible corrections?
lbf78SvgnInt31 is offline   Reply With Quote
Old 07-26-2003, 04:56 PM   #2
Leipper
Profile:
If yours is like the one on my 75, you will need to get at the L brackets on each side that mount the radio to the fold down door. They seem to have rivets to the door but screws to the radio.
What I did was to remove the whole shebang under the credenza. That was only a few screws. Then I could get to the radio. (Anyone need a circa 75 Airstream 8-track in mount or tambour door assemblies for the front divan or over bed?)
You could mount a more modern version in the same place but I am looking at putting it in the overhead. I think I can route the wire bundle up up the wall behind the front roadside speaker. You could also put it underside the credenza and fix up a magazine rack or storage compartment in the space below.
in regards the speakers - sounds like a loose connection, Once you get the radio out you can check.
Bryan
Leipper is online now   Reply With Quote
Old 07-26-2003, 05:01 PM   #3
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
When I read this, I thought, some poor soul that has a collection of 8-tracks.
Glad to see you're upgrading!
Silvertwinkie is online now   Reply With Quote
Old 07-26-2003, 08:01 PM   #4
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
8 track!
I was wondering if maybe I could get a hold your 8 track player? I have been looking for one to put in my Overlander to play all this dinosaur rock I've got stacked up in my closet. An ex-roomate dumped them on me in the late 80's. Is it in decent shape? All the knobs and complete? I might be able to fix it.
Let me know.
Chas
Chas is offline   Reply With Quote
Old 07-26-2003, 08:19 PM   #5
wingfoot
Profile:
I am doing the same job on an 87 Sovereign. The unit is a Sony and it is a near perfect fit. I will get you the model, etc. tomorrow and forward.
wingfoot is offline   Reply With Quote
Air Conditioner Replacement John Sims Furnaces, Heaters, Fireplaces & Air Conditioning 22 08-22-2006 10:46 AM
Looking for NOS replacement Shower curtian track and curtian riders TiredIron General Interior Topics 8 03-14-2004 09:43 AM
Suburban Furnace Replacement Craig Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-31-2003 01:53 PM
A/C unit size input.... Silvertwinkie Our Community 4 09-04-2003 06:05 AM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 11:10 AM
