The radio/8 track unit built into the living room cabinet of my 1978 31'
Sovereign International does not work. I have removed all the screws that hold the facica in which it is mounted. It is loose in the enclosure but I can only move it around about 1/2" to 3/4". There is an 8 track tape storage unit pop riveted to the facica. Can any one tell me how to get this thing the rest of the way out?
I actually would like to replace this with a more modern radio/CD player. Has any one else already made this change? If so, what kind of unit did you select? Was it a "drop-in" replacement?
Also, only one of the two speakers in each end of the trailer appears to be working. Any thoughts on the cause(s) and possible corrections?
