Old 02-20-2014, 10:18 AM   #1
Darlington , South Carolina
Jack for trailer/spare tire suggestions
I am a newbie to camping, I am enjoying learning so much!
I bought my trailer without a spare and any kind of jack. The towing vehicle I have is a 1980 GMC Suburban with original jack; unfortunately, that jack doesn't work properly. What would be a good jack to get for both the Sovereign and Suburban?
Also, what advice can I get as to how/where to acquire a spare tire for the Sovereign as well as where to store it?
jrussjr is offline   Reply With Quote
Old 02-20-2014, 10:21 AM   #2
Where do you live?
Old 02-20-2014, 10:27 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Sovereign has independent torsion axles so if you have a flat you can pull the trailer up onto some blocking using the good wheel on the same side -- either 2x8s or the orange lego blocks work for this -- and change the tire without a jack.
Burb you can get an original jack if you want one on ebay
I carry an 8 ton hydraulic bottle jack which works well for my 'burb and 30' Airstream alike, and carry some plywood pieces to provide a firm support under it. Bottle jacks are compact and reliable and available for around $60-$80 anywhere
Check the classifieds here for tires and rims since people always seem to be switching to 16" wheels and want to sell their old ones
Old 02-20-2014, 10:37 AM   #4
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
This does the job quite well.
Amazon.com: Trailer Aid Tandem Tire Changing Ramp: Automotive
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 02-20-2014, 11:16 AM   #5
rperrym's Avatar
2013 28' Flying Cloud
Hot Springs Village , Arkansas
I also own the Trailer Aid ramp and used it recently to take off all 4 15 inch wheels and mount the 16 inch wheels and Michelins. Worked great.
Rick
rperrym is offline   Reply With Quote
Old 02-20-2014, 11:39 AM   #6
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I carry a small bottle jack, available at any auto parts or hardware store, it will work for both the truck and trailer. I also carry an assortment of 2x6 blocks that can be used for leveling or for a jack pad. Bottle jacks have a small base and can tip over if the ground is soft or unlevel.
I also carry a 12v compressor, so in the case of a slow leak from a nail or bad valve I can keep the tire inflated long enough to make it to a tire shop.
If you have 6 lug wheels on your Suburban the wheels are the same bolt pattern as the Airstream. My Tundra and Airstream have the same bolt pattern wheels, but the Tundra tires are a lot too big for the Airstream. I bought a standard 6 lug trailer wheel from a trailer supply house and a decent used tire for a spare, the idea is for the spare to get me to the nearest tire shop to replace the blown tire.
Make sure you have a lug wrench too! having a jack and a spare will do you no good if you can't get the lug nuts off!
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 02-20-2014, 01:44 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
While less of a problem with 1970s trailer, a fact to consider is that some wheels have limited lug wrench clearance. A tire cross will not fit, nor will the wrenches that come with most cars or trucks.
Old 02-20-2014, 04:31 PM   #8
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Echo the carrying of a bottle jack. Not expensive, don't take up much room, and with a stack of "lego blocks" you can cope with just about any kind of unforeseen complication with either tires, hitch, or whatever!
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is online now   Reply With Quote
Old 02-20-2014, 04:36 PM   #9
switz's Avatar
2014 30' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Lego blocks have an issue on soft earth or sand. The first layer will sink in until the block has bottomed out like a cookie cutter.
Then the trailer was not level any more......I wondered what had happened.
Old 02-20-2014, 04:45 PM   #10
2000 30' Excella
Toledo , Ohio
There is a spare tire bracket that mounts under the front of your Airstream , Andy will have them at Inland Rv . Your spare wheel wants to have 0" offset so it should be a trailer wheel not a truck wheel hope this helps.
woodfox45 is offline   Reply With Quote
Old 02-20-2014, 04:53 PM   #11
switz's Avatar
2014 30' Classic
Images: 8
This link is to a 3 ton combination bottle jack/jack stand. I carry two of them.
http://www.toolsmithonline.com/produ...ack-Stand.html
Old 02-20-2014, 06:09 PM   #12
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I don't have the Trailer Aid ramp.
I use an oil change/auto service ramp- works the same way.
At work we have taken 3-4 foot sections of 8x8 lumber, cut it diagonally, and have 2 trailer change a flat ramps.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 09-13-2014, 08:04 AM   #13
m.hony's Avatar
2013 30' Classic
Name:	ImageUploadedByAirstream Forums1410617060.111085.jpg
It doubled as a step when needed-
TAC #MS-10
Airforums #70955
Old 02-03-2015, 10:32 AM   #14
78black's Avatar
I added a spare tire holder under the front near the propane tanks- just like the newer models.
Name:   ImageUploadedByAirstream Forums1422984675.236776.jpg
I'll post the work pics if anyone's interested. It turned out great! I used a pickup under-bed tire lift.
78black is offline   Reply With Quote
235/75R15XL vs 225/75-15 trailer tire perryg114 Tires 129 07-18-2012 01:59 PM
Jack & Lug nut wrench Tim_S Tires 41 10-31-2011 08:27 AM
Vintage Tongue Jack - Reese IndyAnne Jacks, Stabilizers, Lifting and Leveling 11 10-19-2011 01:32 PM
Suggestions for a spare tire carrier? NicheVintage Tires 5 04-28-2011 10:59 PM
Need Tongue Jack - Suggestions? kj78133 Jacks, Stabilizers, Lifting and Leveling 16 02-23-2011 05:55 PM
Copyright 2002-2015 Social Knowledge, LLC All Rights Reserved.
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
