02-20-2014, 10:18 AM
Darlington
, South Carolina
Jack for trailer/spare tire suggestions
I am a newbie to camping, I am enjoying learning so much!
I bought my trailer without a spare and any kind of jack. The towing vehicle I have is a 1980 GMC Suburban with original jack; unfortunately, that jack doesn't work properly. What would be a good jack to get for both the Sovereign and Suburban?
Also, what advice can I get as to how/where to acquire a spare tire for the Sovereign as well as where to store it?
02-20-2014, 10:21 AM
Corona
Where do you live?
02-20-2014, 10:27 AM
Wise Elder
2010 30' Classic
South of the river
Sovereign has independent torsion axles so if you have a flat you can pull the trailer up onto some blocking using the good wheel on the same side -- either 2x8s or the orange lego blocks work for this -- and change the tire without a jack.
Burb you can get an original jack if you want one on ebay
I carry an 8 ton hydraulic bottle jack which works well for my 'burb and 30' Airstream alike, and carry some plywood pieces to provide a firm support under it. Bottle jacks are compact and reliable and available for around $60-$80 anywhere
Check the classifieds here for tires and rims since people always seem to be switching to 16" wheels and want to sell their old ones
02-20-2014, 10:37 AM
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson
, Missouri
02-20-2014, 11:16 AM
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village
, Arkansas
I also own the Trailer Aid ramp and used it recently to take off all 4 15 inch wheels and mount the 16 inch wheels and Michelins. Worked great.
Rick
02-20-2014, 11:39 AM
1977 23' Safari
Niagara on the Lake
, Ontario
I carry a small bottle jack, available at any auto parts or hardware store, it will work for both the truck and trailer. I also carry an assortment of 2x6 blocks that can be used for leveling or for a jack pad. Bottle jacks have a small base and can tip over if the ground is soft or unlevel.
I also carry a 12v compressor, so in the case of a slow leak from a nail or bad valve I can keep the tire inflated long enough to make it to a tire shop.
If you have 6 lug wheels on your Suburban the wheels are the same bolt pattern as the Airstream. My Tundra and Airstream have the same bolt pattern wheels, but the Tundra tires are a lot too big for the Airstream. I bought a standard 6 lug trailer wheel from a trailer supply house and a decent used tire for a spare, the idea is for the spare to get me to the nearest tire shop to replace the blown tire.
Make sure you have a lug wrench too! having a jack and a spare will do you no good if you can't get the lug nuts off!
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
02-20-2014, 01:44 PM
Wise Elder
2010 30' Classic
South of the river
While less of a problem with 1970s trailer, a fact to consider is that some wheels have limited lug wrench clearance. A tire cross will not fit, nor will the wrenches that come with most cars or trucks.
02-20-2014, 04:31 PM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
Echo the carrying of a bottle jack. Not expensive, don't take up much room, and with a stack of "lego blocks" you can cope with just about any kind of unforeseen complication with either tires, hitch, or whatever!
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
02-20-2014, 04:36 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Lego blocks have an issue on soft earth or sand. The first layer will sink in until the block has bottomed out like a cookie cutter.
Then the trailer was not level any more......I wondered what had happened.
02-20-2014, 04:45 PM
2000 30' Excella
Toledo
, Ohio
There is a spare tire bracket that mounts under the front of your Airstream , Andy will have them at Inland Rv . Your spare wheel wants to have 0" offset so it should be a trailer wheel not a truck wheel hope this helps.
02-20-2014, 04:53 PM
2014 31' Classic
Apache Junction
This link is to a 3 ton combination bottle jack/jack stand. I carry two of them.
http://www.toolsmithonline.com/produ...ack-Stand.html
02-20-2014, 06:09 PM
2013 30' Classic
Greenwood
, Mississippi
I don't have the Trailer Aid ramp.
I use an oil change/auto service ramp- works the same way.
At work we have taken 3-4 foot sections of 8x8 lumber, cut it diagonally, and have 2 trailer change a flat ramps.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
09-13-2014, 08:04 AM
2013 30' Classic
Greenwood
, Mississippi
It doubled as a step when needed-
TAC #MS-10
Airforums #70955
02-03-2015, 10:32 AM
1977 31' Sovereign
Aubrey
I added a spare tire holder under the front near the propane tanks- just like the newer models. I'll post the work pics if anyone's interested. It turned out great! I used a pickup under-bed tire lift.
02-04-2015, 08:57 PM
1977 31' Sovereign
Aubrey
Originally Posted by 78black
I added a spare tire holder under the front near the propane tanks- just like the newer models. Attachment 231625 I'll post the work pics if anyone's interested. It turned out great! I used a pickup under-bed tire lift.
02-05-2015, 12:25 AM
2014 31' Classic
Apache Junction
I carry a three ton rated combination bottle jack and jack stand. The lock keeps it from falling while the trailer is up in the air.
AlltradeTools - Catalog - 640912 3 Ton All-In-One Bottle Jack/Jack Stand
02-05-2015, 06:22 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Bottle jack for Tow Vehicle
Ramps for Trailer. If using a bottle jack on the trailer be careful to not use the axles as a place to jack. There are four points on an AS that are marked and safe to use a bottle jack on, which is why I use the ramp. Very easy and quick to use.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
02-06-2015, 08:13 AM
2014 31' Classic
Apache Junction
I place the bottle jack between the wheels and lift on the frame doubler.
02-13-2015, 08:13 AM
1977 31' Sovereign
Aubrey
Fyi, as long as only one tire is flat you should be able to hang the bad wheel off a curb or slope if positioned just right, if you don't have a jack.
