Old 01-17-2014, 06:46 PM   #1
tcrum's Avatar
1978 31' Sovereign
Cookeville , Tennessee
GFI outlet location
anybody have an idea on where the gfi outlet would be located on a center bath 31'? All outlets work except, the refrigerator and outside outlet. Any ideas?
tcrum is offline   Reply With Quote
Old 01-17-2014, 07:12 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
There isn't one. You probably have a burned off / loose wire or connection on one of the outlets that doesn't work.
Old 01-17-2014, 07:25 PM   #3
tcrum's Avatar
1978 31' Sovereign
I have been going crazy trying to find one. I was told all trailers build in 1978 would have one. Will try to sniff it out tomorrow.
Old 01-17-2014, 07:58 PM   #4
Well Preserved
1993 21' Sovereign
The standard started in 1978, covering most 1979 models, and only included the bathroom outlets. If in doubt, check your breaker box. Most early GFCIs were mounted as part of the breaker for the area mandated by the code.
Old 01-17-2014, 08:29 PM   #5
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
probably in the breaker box.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
He is your friend, your partner, your defender, your dog. You owe it to him to be worthy of such devotion.
bwoodtx is offline   Reply With Quote
Old 01-17-2014, 08:30 PM   #6
switz's Avatar
2014 30' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
One would find a GFI outlet with reset/test button in the middle early in a circuit and everything downstream was then protected by that GFI. Everything upstream was NOT protected.
Old 01-17-2014, 08:41 PM   #7
1988 32' Excella
Robbinsville , New Jersey
The trailers I've seen from the 80s to early 90s had a GFI circuit breaker to protect all outlets on one circuit, not an outlet in the circuit.
Old 01-22-2014, 07:33 AM   #8
87MH's Avatar
1978 31' Sovereign
Images: 292
Bathroom.....behind the mirror.
The GFI is actually located in the breaker panel behind the rearmost closet door.
If there is any dust or grease build up on the receptacle behind the mirror
the GFI may well trip while you are showering just from the dust/grease/crap becoming wet with moisture/water droplets and trip the GFI.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 01-22-2014, 07:41 AM   #9
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Now that explains why the breaker in that box tripped. Didn't know it was a GFI and didn't know why it tripped.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 01-22-2014, 07:45 AM   #10
tony6373's Avatar
2000 28' Excella
1994 31' Legacy 30
Hillsboro , Texas
Gfi
In my M/H the GFI function is handled by a breaker in the box but some PO replaced it with a standard breaker. They are expensive... cost me about $75 to replace.
Tony T
2000 28' Classic TT
1994 30' Land Yacht M/H
tony6373 is offline   Reply With Quote
Old 01-22-2014, 08:00 AM   #11
87MH's Avatar
1978 31' Sovereign
Images: 292
Other recepticals on this circuit.
From the attached schematic you can follow this circuit...if not modified, the circuit supplies the bedroom, bathroom, outside receptacle, and the univolt.
Any problem with any of these receptacles could cause the GFI to trip.
I've been into most of the electrical devices on the '78 at one time or another...mostly during the rebuild. The problem is there are so many brain farts covering the important stuff I need a memory refresh to retrieve what the current page item is referring to.
Dennis
WBCCI # 1113
AirForums #1737
Copyright 2002-2015 Social Knowledge, LLC All Rights Reserved.
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
