Hi There, I am looking at getting a 34 Limited. I have looked at a few of them so far. I noticed on both that there is a change inthe flooring elevation between the dinette and the galley cabinets. Is this normal or is there an inherant frame issue in this area? The difference is likely around a 1/4 inch. Also what color are the awnings on these woodgrain accent units?
Hello. I owned a 1985 34' Limited and did not have anything like what you state. Sounds as if there might be a frame issue there. Any pictures? Where is the trailer located? If near ocean, could have significant frame issues due to the salt air.
I don't believe either one spent time near the ocean. They don't seem to have corrosion anywhere obvious. It is very strange that they both have the same thing. no pics. I am going to go look again. I will get pictures then.
