Replacing Original International Microwave Oven
Hi All,
I'm looking for some advice on what to replace a recently deceased microwave oven with, to be installed on a 1974 International travel trailer. Pretty sure the dead oven is at or near original model (as in, from 1974), so it had a very good run. Did not use a turning plate, unlike most current models. 1974 Airstream manual doesn't indicate power specs just for the microwave, but we don't want a replacement oven model to overpower our existing circuits. In cold weather, the old oven would risk tripping the circuits if, say, a space heater was also turned on at the same time. Trailer is currently in a remote second location, so I can't inspect a possible display of old oven specs mounted on the unit.
Must be no larger than 21" wide, by 10.25" high, by 11.25" deep, installed just above the frig.
Many thanks in advance for advice as to specific new oven makes and models.
John
