Old 10-31-2008, 10:11 PM   #1
Senshi's Avatar
1980 25' International
Napanee , Ontario
Awning roller on International 25 ft
I am looking to purchase an International 25 ft. I have not personnally inspected it yet but I was told the awning roller was wrecked and was therefore removed. However, the braces that hinge from the bottom are supposed to be there yet.
What was the length of the roller on that trailer and can one purchase the roller alone?
Senshi is offline   Reply With Quote
Old 10-31-2008, 10:58 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Just the roller? Yes. What about the fabric, rafter arms, and braces? Did they save everything but the roller tube?
The roller should be about 15 feet, but you will need to measure the hardware that's still attached to make sure. It may be an inch or three more or less than that.
Old 11-01-2008, 06:02 AM   #3
Kevin245's Avatar
The short answer is yes you can buy a new tube, but like Overlander says, you need to be concerned about the condition of the remaining hardware. Tube damage usually means overload on the canopy (water, snow, etc) which can damage all sorts of awning components.
The other issue (I'm dealing with at this moment) is replacement parts availablility. If the unit is old you may have to do some digging, bartering, or (in my case) modify newer components to work for your application.
Good Luck,
Kevin
Eleanor Roosevelt
Old 11-01-2008, 06:11 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
One thing to consider is the make of the awning. If it was a Zipdee, replacement would just be a phone call away. Others may not be as easy.
Richard
Old 11-01-2008, 12:57 PM   #5
Senshi's Avatar
Napanee , Ontario
The trailer is an '80 International 25ft so parts might be an issue. I believe the only thing remaining are the two braces assuming that refers to the two parts that are hinged at the bottom of the trailer and conform to the contour of the trailer. I will know more next week as I am going to pick it up on Monday.
Old 11-07-2008, 06:25 PM   #6
Senshi's Avatar
Napanee , Ontario
Got the trailer and got the answer about the awning. There is not enough left to make it worth buying the parts to replace it. So, somewhere down the trail we will be looking at buying a new one.
Best way to hold roller shades bgarrison Upholstery, Blinds, Walls & Interior Finishes 8 04-07-2009 05:57 PM
Bent awning roller repair gparker Awnings 12 03-09-2007 02:28 AM
'74 International awning hrowley Awnings 1 06-15-2006 04:53 PM
? carter shade awning roller tube retro-active-couple Awnings 3 06-23-2004 03:56 PM
