Problems
I put on the new cover today and found two minor problems.
1. I need to hacksaw off the threaded rod which sticks out the bottom where the strap goes. With the strap routed around the rod, the cover is too tight.
2. I want to reroute the rubber propane hose through the hole in the pan the tanks sit in because it interferes with the cover as it is currently routed outside the pan.
When I get these two items done, the cover should fit quite well; as it is, it is way too tight. The new cover is worlds better constructed than was the original cover.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
