Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > International > 2003 International
Old 01-26-2003, 08:18 PM   #1
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Hot water piping
I had a roll of hot water pipe insulation laying around the shop for several years. It is adhesive-backed foam about 1/8" thick faced with aluminum foil.
In the AS, the water heater is under the front dinette seat, quite far from the galley sink and bathroom. I insulated all of the hot water (red) PEX tubing under the front dinette seat and back along the wheel well to the bathroom. At that point, I ran out of the insulation, but I will buy another roll and do as much as I can underneath the bathroom sink and under the galley sink.
The instructions called for spiral wrapping the insulation. That is impractical in the confines, so I curled a strip like a "U", lengthwise around the tube and another strip around the top of the "U". I used cable ties about every 3" to bind the sandwich. I did undo some of the clamps holding the piping to apply the insulation.
I also applied several layers of the insulation in the big gap in the foam around the hot water tank where the piping enters and exits. That should keep water in the tank hotter longer.
The water at the bathroom seems hotter now and stays hotter between uses.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 01-26-2003, 08:35 PM   #2
Profile:  LOST , Hawaii
You could also try foam insulation made for insulating water lines. Might be easier for hard to reach areas, you can cut the length you need and slip it over the line from one end.
John
74Argosy24MH is offline   Reply With Quote
Old 01-26-2003, 11:17 PM   #3
Pahaska's Avatar
Images: 12
Slip-on insulation
Most places on the tubing, there are too many clamps and other obsticles to do much with the slip-on insulation.
I tried a piece of the slip-on stuff under the shower floor, but apparently the piping is clamped to the floor just out of my sight so that it will not slip far enough to make much difference. I do have a piece of the slip-on stuff on the vertical run to the bathroom faucet.
John W. Irwin
Old 01-27-2003, 12:35 PM   #4
Profile:  1975 31' Sovereign
Eau Claire , Wisconsin
insulation
John, I don't know if it makes any difference where you are and I don't even know if this is really an issue. But, it seems logical to me that those hot water pipes might disperse heat in the winter to keep other things warm which might benefit. I would guess this would be more important to me here in Wisconsin than you in Texas.
Brouck
bhsl8 is offline   Reply With Quote
Old 01-27-2003, 01:19 PM   #5
Pahaska's Avatar
Images: 12
bhsl8
The volume in the tubes is so small and the fact is that the water would not be hot except immediately after drawing water, so I doubt that it would make any appreciable difference.
Also, this is one of the new Internationals and does not have the full belly pan. It is not meant as a severe cold weather trailer, nor would I attempt to use it at lower temperatures than the mid-20s. One thing I would do is install a low-wattage 120v bulb to provide some heat under the shower pan to use it in marginal weather.
It made me think, though, that a small pump circulating water from the water heater could certainly be a freeze deterrent in a trailer used in severe cold weather.
There was a web site I saw sometime back that uses the water heater, a small radiator, a circulating pump, and a fan to heat the trailer. The author claims it is very successful.
John W. Irwin
Old 01-27-2003, 02:51 PM   #6
I was just wondering. I keep trying to figure out efficient ways to camp deeper into the season. I didn't realize that the internationals were somewhat panless. Does that make it easier to effect some maintainence/repairs etc.?
Brouck
Old 01-27-2003, 03:18 PM   #7
Pahaska's Avatar
Images: 12
Belly pan
Since I have no intention of using the International in severe cold weather, I'm just as glad there is no belly pan. I have overnighted in it at just about freezing and with the carpet and pad, the floor was quite warm.
I think long term, there will be a lot less to worry about underneath with full access to the frame and no insulation that could get wet. I have already strung some wires along the frame that would have been difficult with a belly pan.
John W. Irwin
Old 01-29-2003, 06:43 AM   #8
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Protecting the Propane Lines
That black foam tubing that you can use to insulate pipes also does a pretty good job in protecting the gas lines. I bought some of the larger diameter tubing and covered the gas lines that run exposed below the underbelly.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 01-29-2003, 07:19 AM   #9
Pahaska's Avatar
Images: 12
Good advice, Jack
The exposed propane lines on my trailer are encased in a little tougher version of the foam pipe insulation for most of their length. They aren't covered where they branch out under the galley to go up through the floor. I have intentions of protecting that area, as well.
John W. Irwin
Pingbacks are On
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
Nobody needs a hot water heater!!! Rick Alston Off Topic Forum 109 02-13-2004 09:52 PM
Hot Water to Hot Raptorrider2001 Water Heaters, Filters & Pumps 3 08-20-2003 06:58 PM
Another faucet question--no hot water... heyskipper Sinks, Showers & Toilets 3 03-13-2003 06:06 AM
Looking for ideas hot water FrankR Water Heaters, Filters & Pumps 3 05-09-2002 10:28 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
