Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1984 - 1989 Sovereign
Old 04-01-2009, 07:08 AM   #1
Alsupp's Avatar
1984 31' Sovereign
Andover , Kansas
Monitor Panel Bulb Replacement - '83
I tried a search of threads and came up empty - does anybody know how to change the burnt out bulbs for the systems monitor panel in an '83 Sovereign? It looks like there are five pop rivets to be drilled out, but that appears to hold the panel to the front facia, not allow access to replace bulbs. Does the black panel just pop off? Thanks! John
Alsupp is offline   Reply With Quote
Old 04-02-2009, 10:56 AM   #2
1985 25' Sovereign
Valley Center , California
I need to know, too! Please post the details if you find out how
BogieGolf is offline   Reply With Quote
Old 04-03-2009, 07:57 AM   #3
Alsupp's Avatar
1984 31' Sovereign
Andover , Kansas
OK - Man, is Airstream cool! They have on their website a "vintage trailer" tech support feature. I emailed them this question and had an answer in less than a day!
Basically, you take a stiff putty knife or the like and pry it out between the metal trim and the plastic cowl. The panel assembly is held in with four aluminum clips. Once you get one popped off, just keep working it out. Once you see the back, it is easy to tell how to get to the burnt out bulbs. I replaced the indicator bulbs (bulb #53) with ones I bought at a local O'Reilly's Auto Parts store. Slick as a whistle!
Old 04-03-2009, 08:36 AM   #4
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Alsupp is absolutely correct!
Just one word of cautions, regarding the ABS plastic panel.
You must know..
By this time, it's very fragile..so proceed slowly..I would say the better word is not to be too rough with whatever tool you use to pry the panel apart. Good Luck..
BTW, the spring loaded switch is gonna be prone to breakage due to age..I'd recommend that you find a source and, obtain a spare for that replacement..It just a matter of time..
Replaced mine last year and, it was not easy to find..
Good Luck~!
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 04-03-2009, 08:49 AM   #5
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
Easy does it! Best to have two people get the panel out then one to hold it while the
bulbs are being replaced by the other. Takes two to tango with this pile of wires.
Getting all the wires tucked in is the tricky part.
Mike Leary is offline   Reply With Quote
Old 02-18-2014, 12:13 PM   #6
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
This was helpful-- I know it's an old thread, but thank you!
Skatiero is offline   Reply With Quote
Old 02-22-2014, 06:29 PM   #7
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
I got the panel out and replaced all 11 bulbs😁 Working good! Thanks
Monitor Panel tomdaniel General Repair Forum 1 08-18-2008 08:08 PM
Monitor panel '89 Excella BillTex General Repair Forum 9 09-26-2007 03:40 PM
Monitor Panel Darrell Root General Interior Topics 4 05-14-2007 07:15 PM
Monitor Panel Gareth Electrical - Systems, Generators, Batteries & Solar 8 06-25-2006 08:57 AM
345 Monitor Panel Howard Lefkowitz Mechanics Corner - Engines, Transmission & More... 3 10-11-2004 04:07 PM
