09-20-2006, 08:32 AM
WBCCI 11067 WDCU
1986 25' Sovereign
Atlanta
, Georgia
Dry rot on the flooring above the stair
Hey guys,
I recently ripped up the carpeting in my new 86 and found some moisture issues in the front and by the front door and navigation table. The chip board sub-floor near the door is rotted out and I was able to poke my finger through it. I think I am OK on repairing the section of flooring, but I was trying to figure out the cause.
I noticed they sealed up the seem between the underbelly and the plastic transition strip with expandle foam and probably took care of the problem in the front. I think the area around the front door my be an unsolved problem. I noticed that there is a gap between the stair well and the plastic underbelly that I don't remember having on my 1978 International. Do you guys have any gaps?
Chris Keysor
WBCCI 11067
1986 Sovereign 25' CB
2007 Chevy Silverado 1500
2007 Toyota Land Cruiser
09-20-2006, 08:40 AM
INSANITY CENTRAL
1986 32' Excella
Airstream Funeral Coach
Citrus Heights
Chris, My 86 Excella had a similar situation. to a much lesser degree. No floor replacement needed. My problem was a leaking gasket on top of the roof where the center lights are. The water was leaking thru and running down the inside of the interior walls, then migrated to the floor and behind the stove. I'm currently resealing all my roof holes. Hope this helps Tim
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
09-20-2006, 10:14 AM
WBCCI 11067 WDCU
1986 25' Sovereign
Atlanta
, Georgia
ah yes
Thanks, I didn't think about that as a possibility, but very likely. Which center lights and/or gasket are you referring?
Chris Keysor
WBCCI 11067
09-20-2006, 12:14 PM
Columbia
, South Carolina
Hey, I have a much older trailer but what did you use to replace the gaskets??
Happy Camping
McLogger, AIR # 16452
09-20-2006, 12:39 PM
2016 25' Flying Cloud
Sunnyvale
Porch Light or A/C Gasket?
We had a leak around the edge of the "porch light" over the door on our '25, and that dripped water insode door frame and onto floor just inside the door... A little Vulkem and some work replacing the bulb with an amber version (think "bug light..") and cleaning up the frosted plastic lens and all was well.
We also had a leak around the air conditioner "gasket", which is 14" x 14" piece of black foam between the roof and the bottom of the A/C.. When it hardens and leaks, water will drip onto floor of trailer in rain or when A/C is running and condensate pools above roof level. This can also get water between inner and outer skins and then gravity will do its thing, and water will somehow make floor wet...
John McG
Condoluminum
09-20-2006, 05:27 PM
INSANITY CENTRAL
1986 32' Excella
Citrus Heights
use the search butto to find out about sealing-Chris my rig is a little longer than yours it has had the light in the dining are replaced with a fantastic fan. That's where the leak is. As far as sealing I'm gonna wait up till I go to the Nor Cal Rally and speak with some other folks. In the marine industry we used to use a product called Dolfinite, I know this stuff works that was 20 years ago, hey any one know if it exists? going google
www.popasmoke.com
YETI ( 65 Quart )
09-26-2006, 04:15 PM
WBCCI 11067 WDCU
1986 25' Sovereign
Atlanta
, Georgia
Thanks to all. I think that the center light is the issue and certainly easy enough to fix.
Chris Keysor
WBCCI 11067
