Old 05-25-2019, 11:13 AM   #1
1989 Excella 32 footer.
Russ Abbey's Avatar
1989 32' Excella
Check , Floyd County, Virginia
Water leak
Hi All,
I have a 1989 Excella 32 footer. I started to try to fill my water tank last summer in Virginia Beach, VA. and it shot out the side of the trailer just below the wheel well on the curb side of the trailer. So I just filled from the hose and forgot about till this year. We were at a campground in Jefferson NC, and for some reason when we hooked to the city water it was doing the same as the fill tank from last year. So, checked the button above the stove on the exhaust hood, turned it on and then back off. Still leaked very bad or should I say gushered? Anyway any ideas where to look? I have checked and find not leaks in the lines anywhere I can see, but something has happened.
Was reading in the manual that there are a couple of relays, but not to sure about this? If they are relays, are the snapin's or mabe soldered in or is it part of the piping and I have to make changes? I have a friend coming over tomorrow (Sunday 5/26/19) to try to lend a hand finding the cupert. However, any help would be greatly appreciated here.
73
Russ Abbey
Floyd County Virginia
N4MAV - FCC Call sign for Ham Radio
Russ Abbey is offline   Reply With Quote
Old 05-25-2019, 12:26 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Sounds like you're describing the auto fill function.
There is a solenoid involved in this system.
I'd suggest you look at the plumbing under the cedar closet and check for broken plumbing and leaks. Shark bite fittings are your new best friend!
Btw, the auto fill system is a neat thing when working well.
Old 05-25-2019, 03:08 PM   #3
Russ Abbey's Avatar
1989 32' Excella
RE: Water leak
Thanks Atomic, I will check for that relay and yes, that is what I am talking about. I know that it has never worked (the auto fill) since I purchased the AS. If this is what it is, is the relay in a socket? Or is it soldered in? I can do either, but would prefer the one in a socket and will convert it over if I need to.
73
Russ Abbey
Old 05-25-2019, 03:44 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
It is not a relay, rather a solenoid plumbed into the line. As I recall it's 2 wires from the harness, and an in and out water line. Pretty easy. It might just have gunk in it.
Old 05-26-2019, 06:23 AM   #5
Russ Abbey's Avatar
1989 32' Excella
Thank you again Atomic, I have found the solenoid, so will see if this is the problem. I'll pull it out and see if it is clogged up or if I need to replace it. I am assuming that VTS or Airstream has them in stock, but I'll also check with Amazon and others. Like my local plumbing house.
73
Russ Abbey
Old 05-27-2019, 08:01 AM   #6
Russ Abbey's Avatar
1989 32' Excella
RE: Water leak
Yesterday (Sunday) a buddy came over and helped me do some trouble shooting. The wires and plumbing are terrible! I have seen my Son when he was smaller and a lot younger do better work then who ever decided to do the work in there. Anyway there is not power to the solenoid so looks like more trouble shooting is in store. I will have to pull the couch to get to the 12 VDC panel (another great idea from someone?) and see if the breaker is bad or just what is back there. It could be as simple as a mouse biting on the wires or something like a major redo os the 12 VDC system. In other words, to be continued.
Thanks for the help on this and I will keep you informed.
73
Russ Abbey
Old 06-04-2019, 01:53 PM   #7
Russ Abbey's Avatar
1989 32' Excella
RE: Water leak
Found it! The air tube on the fill cover had slipped off of the nipple it is supposed to be on. It took 2 Saturdays to actually find it, but doing any trouble shooting on my part is dependent on the temperatures. We also found out that the last campground or so had clogged the water filter we didn't know was there so had to be replaced. Of course this may have been a long time ago now, but it showed up on my watch. Anyway a new solenoid is on the way along with a 100 feet of Pex, both red and blue. We shall see how far I get with this. :>)
Also new wire was installed from the breaker to the solenoid by running new wires to where it was needed via the ceiling/walls. Not my idea of how to spend the weekend. I'll be taking some pictures as I pull stuff out and putting in new wiring and plumbing. Right now it looks like we can get new pipe to the bathroom and heater without much problem. The first time I looked it was a nightmare but found another way to do it I hope.
73
Hint: Don't be in a Navy hospital bed in Portsmouth, Va in a full body cast in August when the AC goes out and your body temp goes to 108 degrees F. They had to cut the body cast and load it with ice to get my core back down. The good side of it was I was able to scratch all of the itches till the doctor got there.
Russ Abbey
Old 06-04-2019, 02:50 PM   #8
2007 22' International CCD
Yowch! No fun at all.
rmkrum is online now   Reply With Quote
That darned leak!! Need help from leak experts !! nickclifford General Repair Forum 20 12-03-2015 05:52 PM
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
Water Leak above Black water tank temcotom Waste Systems, Tanks & Totes 1 06-29-2005 11:03 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
