Old 09-15-2015, 08:12 AM   #1
1989 29' Excella
Cumming , Georgia
Procedure - Using the Heat for the first time
Hi,
Anyone know of an existing thread they can point me to regarding the best practice procure for making sure your heat is working correctly the first time it's being used for cold camping?
thanks
Dave
davcarv is offline   Reply With Quote
Old 09-15-2015, 08:53 AM   #2
2015 16' Sport
Portland , Oregon
One thing is blow the spiders out of the burner with a can of dust off. If there are webs in there they will cause your wiring to get burned.
leedav is offline   Reply With Quote
Old 09-15-2015, 09:09 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Good general info here,
http://wbccicaravan.wbcci.net/files/...our-rv-iii.pdf
MICHAEL
Old 09-15-2015, 10:56 AM   #4
2014 30' Flying Cloud
Ponce Inlet , Florida
Be prepared for your smoke detector to go off. Ours went off the first 2 times we used the furnace. Scared the you know what out of me but I guess it was a good test of the smoke detector.
bunni is offline   Reply With Quote
Old 09-15-2015, 11:00 AM   #5
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
I'd suggest opening windows since there may be a little smell from dust burning off. Not terrible but good airflow through windows or vent fans a good idea.
Dennis
dennis3751 is offline   Reply With Quote
Old 09-16-2015, 05:09 PM   #6
SipStreamer
2010 20' Flying Cloud
Lakeside , Montana
But to answer your question, "the best practice procure for making sure your heat is working correctly", turn it on. See if it blows hot air.
StreamDog is offline   Reply With Quote
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Long Time RVer, first time Airstream(er) Lucas S Member Introductions 4 03-19-2014 03:39 PM
Frisco, TX - Long time lurker, first time poster johnfmiller Member Introductions 11 06-08-2011 07:50 AM
First Time and Full Time! JRoss3030 Member Introductions 9 03-20-2010 11:28 PM
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 08:55 PM
