Old 08-06-2015, 03:08 PM   #1
1989 29' Excella
Cumming , Georgia
Need a Grey holding Tank
Hi,
I'm in need of a new Grey Holding Tank for an 89, 29 Foot Excella.
I've checked with AS and no luck, ... not available anymore.
they did give the name of someone in Ala who might have a source.
I've also checked with Vintage Trailer Supply and AS parts.
Any thoughts?
Dave
davcarv is offline   Reply With Quote
Old 08-06-2015, 03:28 PM   #2
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
you can get them custom made. Do a search for custom holding tanks. They are definitely more pricey, but you can sometimes get a bigger capacity. Or you can make your own, but as someone that did it, I'd encourage you to find something that is just similar in size.
robwok is offline   Reply With Quote
Old 08-06-2015, 03:31 PM   #3
1989 29' Excella
Cumming , Georgia
thanks Robwok, .. that may be the path I have to take.
Old 08-06-2015, 04:33 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Marine suppliers are good sources of custom made holding tanks.
MICHAEL
Old 08-06-2015, 05:52 PM   #5
1984 31' Sovereign
1978 Argosy 24
Zavalla , Texas
I put in holding tanks in three different sailboats, the last a flexible tank that worked well. Defender Marine and West Marine were good sources. Out of Doors Mart in NC might be a source for Airstream type replacement. They always seemed up on parts replacement.
Good Luck
Orlop is offline   Reply With Quote
Old 08-06-2015, 09:16 PM   #6
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Check with Inca Plastics. They were the historical supplier of tanks and might have the mold or tank you need. I got a black tank for my '73 that is essentially the exact same tank.
Old 08-07-2015, 11:59 AM   #7
1982 34' Limited
Lamesa , Texas
Hello,
Saw your post needing a gray tank. Several years ago I salvaged out a 87' Excella 27 ft trailer. It MIGHT be possible that the tank out of it would work.
The general dimension are 21 1/2' x 8 1/2' x 56' with a corner cut out that I did not measure. If these are the GENERAL dimensions then I will measure the cutout so we can be specific as well as the inlet and outlet holes size and location.
Just let me know if you are interested....
We just got back from spending time in the Conyers area.....
Jimmy
Mayjam2 is offline   Reply With Quote
Old 08-10-2015, 02:31 PM   #8
1989 29' Excella
Cumming , Georgia
Hi Jimmy and thanks for the response. I think tough that my holding tank is thinner at it's widest point.
Old 08-10-2015, 03:06 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Tanks.com, or something like that, has them listed by size.
You will be able to find one that will work, drill the hole, install the inlet, and done.
These are "off the shelf" and not pricey.
Old 08-10-2015, 06:50 PM   #10
1982 34' Limited
Lamesa , Texas
Just went out and looked at the tank again.
It has an Airstream part number of 601316 stamped in the tank faintly and it is about 6 3/4" deep at the largest end.
Just let me know if it will work for you....will send you photos if I can figure out how to do that!!!
Jimmy
Old 08-13-2015, 10:38 AM   #11
1989 29' Excella
Cumming , Georgia
HI Jimmy,
so the Measurements are,
21 1/2 W' x 6 1/2'H x 56 L?
is there a way you could take a pic of it and text it to me?
my cell is,
678-772-1556
my email is,
davcarv@hotmail.com
Tks
the model # of the grey tank that I need to replace is,
601220
tks
Dave
Old 08-13-2015, 10:39 AM   #12
1989 29' Excella
Cumming , Georgia
Also, it has an indention in it where the valve connection is.
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
The "GEO System" Balck and Grey tank holding tanks adonh Waste Systems, Tanks & Totes 1 05-06-2013 12:05 PM
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 07:52 AM
Why aren't the grey and black holding tanks one? Kistler Waste Systems, Tanks & Totes 26 06-02-2004 03:41 PM
