Old 01-21-2008, 07:23 PM   #1
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Looking For Floor Trim Suggestions
I am putting a new laminate wood floating floor in our 1987 Excella 1000 and I am looking for suggestions on what trim material to use around the radius on the rear of the coach. Our trailer has a rear door in the bedroom and the bed is perpendicular to the road side of the coach. So I have a radius that I am going to have to trim around. Being a floating floor the flooring must remain 3/8" from the wall. I am using a stained shoe molding in the rest of the coach. As of yet I haven't come up with anything that suits my taste. Does anybody have any suggestions??? I have attached and interior shot with the carpeting ripped out and ready for the floating floor. I will post more pictures as the work progresses.
Name:	Galley Forward 1.JPG
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 01-21-2008, 07:29 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
How about an ivory colored 2" crown molding?
Old 01-21-2008, 07:33 PM   #3
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Couple ideas for you: I know that rubber-composite "trim" is made, I've used the casing for curved windows in homes. I would think rubber base shoe would be available somewhere- maybe do a google search for it. You could also make a steam-box, for steaming and then bending your wood base shoe. Another choice that might work is to check out the "fake" base shoe from Home Depot, sold in the aisle where they sell the laminate flooring. I seem to remember it being fairly flexible. Have fun- tim
tphan is offline   Reply With Quote
Old 01-21-2008, 08:23 PM   #4
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
http://www.airforums.com/forums/f36/...dge-23252.html
Not sure if this is what you are looking for but here are a couple of pics of what I did.
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 02-12-2008, 04:07 PM   #5
DEITZ645's Avatar
Thanks for the suggestions. I ended up going with a "plastic" shoe molding found at Home Depot, it is very flexible and will conform nicely to the radius in the bedroom. My attempts to work on the trailer last weekend were thwarted by the weather. I did not want to be tracking snow and water in and out of the trailer since I have most of the floor down. It is 99% complete, all that is left is a few planks in the bedroom and the molding. I should have it completed this weekend, that is if mother nature cooperates.
Here are a few pictures of the almost completed project. I am pretty pleased with how it came out. The saving grace in this project was an electric undercut saw rented from Home Depot for a day.
ID:	54218   Click image for larger version
ID:	54220   Click image for larger version
ID:	54222   Click image for larger version
ID:	54224   Click image for larger version
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 02-12-2008, 05:57 PM   #6
2000 34' Limited S/O
Jamestown , North Carolina
That really looks great. What type of floor did you use?
2000 34' Limited with Sofa Slide
06 Dodge 3500 Cummins Turbodiesel 4X4 Quad Cab Hensley Hitch Pressure Pro Centramatics
WBCCI #4358
tslanier is offline   Reply With Quote
Old 02-12-2008, 06:59 PM   #7
DEITZ645's Avatar
Flooring Used
tslanier,
Thanks, it is a laminate wood floating flooring product by a company called Wilsonart. It is a tap-lock system so there is no gluing. It went together pretty easy, but I am pretty sure the planks will never separate. The color is one of the cherries, which one it is I don't remember. The best part about the floor is it was basically "free". I used what was leftover from when we remodeled the interior of our non-mobile home
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 02-13-2008, 09:25 AM   #8
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Nice looking floor.
Consider (if you haven't) using a sealer at/under the threashold trim to keep tracked water from seeping down into the flooring or sub-floor.
Dave
Fyrzowt is offline   Reply With Quote
Laminate Floor Trim? Steve Heywood Repairing/Replacing Floor &/or Frame 5 12-18-2005 06:41 PM
Looking for suggestions Cedars Our Community 1 07-15-2005 12:05 PM
Curved trim for pergo floor TOM CRUMP Floor Finishes 6 04-22-2005 01:15 PM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
Suggestions Inland RV Center, In Our Community 5 10-30-2002 06:12 PM
