Old 04-09-2007, 03:44 PM   #1
1989 25' Excella
cincinnati , Ohio
interior wall covering material
I am having new drapes made for my 1989 25 foot excella and having the couch redone to. The problem is, I can't find gray velvet material to replace the mauve velvet currently on the walls. Does anyone know of a source for gray velvet or a replacement material that will work? Help!!
mouse is offline   Reply With Quote
Old 04-09-2007, 03:46 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
http://www.airforums.com/forum...ial-31500.html
Tom
Old 04-09-2007, 04:11 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Material
The upholstery grade of velvet should be a heavy cotton velvet. Check your local yellow pages, there are stores that sell specifically drape, curtain and upholstery, but they are few and far between.
Do be very very aware that velvet has a nap. If you're not familiar with the term think of a cat. If you rub it head to tail you're going with the nap, rub it the wrong way and you're going against the nap. You can feel the difference...right before the cat claws you.
Every piece of your velvet must be put in so that the smooth direction is downward. There is more waste when choosing a fabric with a nap as opposed to one that doesn't have one. (However it's my personal opinion that whenever you're doing upholstery act like the fabric HAS a nap even if you can't feel or see it.). If you're planning to cover the wall, too, you'll probably want to get heavy flexible plastic or posterboard, and attach the fabric to that, then glue that to the walls.
I've shopped at a chain called "Calico Corner" and also Jo-Ann Fabrics has a lot of upholstery stuff. You'll probably have to special order it.
Paula Ford
Awning material source NASCAR345 Awnings 6 03-03-2003 11:12 PM
Seals and Weatherstriping niftypkg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 10-29-2002 09:40 AM
Broken Lite Shade Fix wagsrp General Interior Topics 1 10-13-2002 09:11 AM
Interior improvements PeterH-Airstreamer Airstream Motorhome Forums 18 04-02-2002 12:27 PM
