Old 07-27-2003, 03:36 AM   #1
longhauler's Avatar
Hail Damaged Excella 35......
Hello...
Check out this hail damage... This is a '91 Excella 35 coming up at auction (was a writeoff) I'm looking to bid on it. It is hours from where I live and all I have is a few photos and a brief option list. It should go cheap (I will be buying it over the phone if the price is right) I really know little about it - would anyone take a look at the photos I have to help determine what this would be worth / options etc. The damage is tolerable and I would likely not fix it anyways. Send me an e-mail at ontario@sympatico.ca and I'll e-mail the photos to you. Thanks in advance. Greg
longhauler is offline   Reply With Quote
Old 07-27-2003, 06:33 AM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Greg, if that's the worst of the hail damage consider it minor. I wouldn't remove this trailer from consideration because of this.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-27-2003, 07:29 AM   #3
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
That's nothing. I got a few hail dents in mine, much bigger than those.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 07-27-2003, 08:11 AM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Thumbs up
If that's the worst, and the rest is in good shape, grab it. That damage is nothing and in some cases normal temp flucuations will lessen the damage unless it already has and it was worse at some point.
Old 07-27-2003, 08:45 AM   #5
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
End caps
Do you have a photo of the end segments? These are made of much thinner aluminum and would be damaged much more severely.
A few years ago, I took an $8000 settlement for hail on my SOB trailer and had the factory replace the roof. A good friend who was parked next to me got the very same settlement and went to the dealer and traded on a brand new unit. The dealer took off very little for the hail damage and my friend had a new trailer at no cost. I'm still kicking myself for not simply trading mine in.
John W. Irwin
WBCCI #9632
Old 07-27-2003, 09:14 AM   #6
nds
As long as the outer skin wasn't torn...
If the only damage is dents and the outer skin wasn't torn in anyway to allow leaks, I wouldn't be too concerned.
I've seen this product advertised and I think it would be ideal for these type of dents. I would think the majority of them could be removed and with most of the dents being on the roof, would only concern myself with those that are actually visible.
The Ding King
nds is offline   Reply With Quote
Old 07-27-2003, 09:19 AM   #7
Chas's Avatar
Images: 22
Man, that baby is totaled!
Why don't you buy it and part it out? I would like to get the Zip Dee window awnings off of it and the front gravel guards! Can you get me the measurements?
Chas
Chas is offline   Reply With Quote
Old 07-27-2003, 09:23 AM   #8
nds
You are kidding, right Chas? Unless you're seeing something I don't in the one picture provided.
Old 07-27-2003, 09:37 AM   #9
Chas's Avatar
Images: 22
Yes I am. Kidding. I really want those window awnings though! What pattern are they? Pacific Blue Ultima I hope.
Chas
Old 07-28-2003, 03:39 AM   #10
longhauler's Avatar
Hello To All.....
I heard it is possible for someone with a WBCCI book look up who owned this unit? If the # is re-assigned would an older book work? I would like to call them (auction only giving me photos - no descriptions) (It is in NC) A day and a half 'till auction closing.
The # is 17553
Thanks for everyones input!!
Fishing for a deal on some awnings, are we Chas ?
Old 07-28-2003, 05:17 AM   #11
Products like the Dent King will only make your Airstream look worse. They may work just fine on steel, but aluminum works entirely different.
Mark
Old 07-28-2003, 05:30 AM   #12
qqq
qqq's Avatar
Go for it!
The AS looks perfect to me, the "salvagedirect.com" site has done a good job with their pics.
I wouldn't worry too much as it is not too old.
Hart
qqq is offline   Reply With Quote
Old 07-28-2003, 06:06 AM   #13
nds
Mark
Why is that? The only thing the tool is supposed to do is pull the dent back out. Pretty much the same tool that they would use if you had it done.
Old 07-28-2003, 06:33 AM   #14
Chas's Avatar
Images: 22
Yes,
And some rock guards which thanks to your pic look to be available!
As far as I.D.'ing the previous WBCCI owner you won't have much luck. First off you need to be a WBCCI member to do so, period. Second, unless this number is still active and even if it is, there is no sure way to determine if this number still applies to this unit and whoever owned it at the time this number was assigned to this unit. Numbers can be reassigned if they become available, like if a member decided not to renew.
Chas
Calling all 70's decade(70-79) EXCELLA 500 owners jaco Airstream Trailer Forums 41 03-19-2018 08:53 PM
2000 Excella 1000 Cracker 1998 Excella 1000 1 02-21-2004 01:19 PM
78 Excella 500 davidz71 Our Community 2 10-17-2002 01:11 PM
