Old 10-25-2004, 04:46 PM   #1
Excellaphant's Avatar
Bathroom Caulking
Anyone have any hints on replacing/adding caulk around the edges of the
shower? Mine appears to have been touched up a few times. It's not
in really bad shape, but I can tell it's going to need fixing.
thanks,
Excellaphant
Excellaphant is offline   Reply With Quote
Old 10-25-2004, 06:33 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I have re-caulked the bathroom in a number of Airstreams. The GE Ivory silicone is the right color and is what is there now. Clean out as much of the old as possible before you apply the new. Cut the tip small, so you lay a narrow bead. Since it is inside and will be protected from the elements and is on fiberglass or ABS it will hold fine. You will be amazed at how much better it looks once you get it done.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 10-25-2004, 09:10 PM   #3
Joe Z's Avatar
MAKE SURE YOU TAPE OFF ALL OF YOUR EDGES UNLESS YOU ARE AN EXPERT AT CAULKING!
The finished product will look much nicer.
1. After removing the old caulking (if needed) wipe the area down with denatured alcohol. This will help the caulk adhere to the surface.
2. Then when applying the masking tape or painters tape leave yourself about an 1/8 inch on each side of the joint.
3. Run a bead of caulk down the joint after you have taped, then smooth your finger over the bead (wiping the excess on a paper towel as you go) and then peel off the tape.
Tuh Duh! Your finished product should look professionally done.
Oh yeah - if you are caulking up to the stainless or aluminim moulding around the shower door use clear caulking and yes, even with clear caulking tape your joints before running a bead.
Joe
Joe Z is offline   Reply With Quote
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 08:01 AM
61 Caravel Bathroom kayelm Sinks, Showers & Toilets 3 09-07-2004 07:17 AM
advice wanted for bathroom sink replacement Shelby Copeland Sinks, Showers & Toilets 8 12-25-2003 07:06 AM
Pergo in the bathroom Chuck Floor Finishes 8 08-05-2003 05:13 PM
Caulking underneath? Kistler Our Community 2 07-10-2003 07:25 AM
