Old 05-30-2014, 04:43 PM   #1
1989 25' Excella
Lone Jack , Missouri
A/C replacement for '89 Excella
Hello all,
I am in a bit of a quandary. I need to replace our A/C due to a compressor failure. So far the only solution has been to replace it with a unit that allows the condensate to run down the outside of the trailer. Is there a unit where I can use the condensate drain line that already exists or is there a work around? Seems like condensate running down the outside of the trailer would eventually discolor/corrode the aluminum besides being unappealing.
Many thanks,
bjeppson is offline   Reply With Quote
Old 05-30-2014, 05:24 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
What's wrong with a Dometic Penguin?
Old 09-10-2014, 06:51 PM   #3
MissPearl's Avatar
1989 29' Excella
Pauline , South Carolina
You can buy, separately, a drain.kit for the dometic penguin. It catches the condensate and pipes it to the existing drain line.
MissPearl is offline   Reply With Quote
Old 09-10-2014, 07:01 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
You have several choices. Either you have been looking in the wrong place or getting the wrong information from your dealer/tech/repair person.
Dometic makes their Aux. Drain Kit #3107688.016 for any Pengiun model that will connect into your internal condensate hose and RVP (Coleman) makes several low profile Mach 8 units with their condensate pump.
Either manufacturer is readily compatible with the internal drain hose arrangement that Airstream uses.
Old 07-07-2016, 01:30 PM   #5
88 Excella 34ft
Puck & Gumby's Avatar
1988 34' Excella
Valrico (Tampa) , Florida
88 Excella A/C replacement
Original equipment on this model was a Coleman Delta TX. The existing hole in the roof appears to be 13"x13". I am not interested in the cost of a low profile or Penguin. Will a Coleman Mach series work with the Dometic 'cup' style drain kit?
"Not all who wander are lost"
Tim and Susan
West Central Florida
88 Excella 34'
05 F250 SD 5.4
Puck & Gumby is offline   Reply With Quote
Old 07-07-2016, 01:34 PM   #6
88 Excella 34ft
1988 34' Excella
Original equipment on my 88 Excella was a Coleman Delta TX. The existing hole in the roof appears to be 13"x13". I am not interested in the cost of a low profile or Penguin. Will a Coleman Mach series work with the Dometic 'cup' style drain kit?
Tim and Susan
88 Excella 34'
05 F250 SD 5.4
Old 07-07-2016, 02:12 PM   #7
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
Yes the drain cups will work takes two gaskets. Look up installation instructions.
thehandyman is offline   Reply With Quote
Old 07-07-2016, 08:13 PM   #8
lewster's Avatar
If you get a Mach 8 series unit, you can order it with their 'condensate pump system' which will automatically feed the condensate directly into your inner drain tube. No other drain kit would be required.
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 5 03-21-2013 03:32 PM
Door Handle - Replacement for 1981 Excella dienst1 General Motorhome Topics 44 10-08-2011 11:36 PM
where do i get replacement parts for a '96 Excella 1000 dufrain 1998 Excella 1000 3 03-28-2008 08:11 AM
Replacement battery box 1985 excella acleiter Batteries, Univolts, Converters & Inverters 9 09-23-2004 10:15 AM
96 excella vent lid replacement help needed dufrain Roof Vents, Skylights & Fans 0 10-30-2003 01:34 PM
