You have several choices. Either you have been looking in the wrong place or getting the wrong information from your dealer/tech/repair person.
Dometic makes their Aux. Drain Kit #3107688.016 for any Pengiun model that will connect into your internal condensate hose and RVP (Coleman) makes several low profile Mach 8 units with their condensate pump.
Either manufacturer is readily compatible with the internal drain hose arrangement that Airstream uses.
lewster
