Old 01-26-2011, 04:40 PM   #1
Cjack
cjack99's Avatar
1989 32' Excella
Hurst , Texas
Cool '89 Excella, Mystery wire bundle, hitch area, photos
Hi All;
Short story, always been a large mass of wires just outside the tank housing, lots of tape. PO seems to have been a genius at rapid engineering with tape.
Anyway, electric lift motor on the jack has always had a loose ground ever since I purchased the Excella, and today it was very cranky, have to jiggle and what not to get it going. Once hooked up it's fine, until you want to drop it again. So I started tightening up the bolts, and discovered his nibs had messed with the mount for the break a way plug, and the tape mass was in the way, so I got after it! Prior to me untaping it, there had been 3 or 4 wires coming from one end of the tape bundle, 1 of which goes to the jack motor, this one I understand, the others are a mystery to me.
Obviously there used to be something wired in up near the hitch point,,,, automatic brake sensors???? Anyway, my thought is to just do away with all the unattached wires, and simplify that mass, loosing at least 5 pounds of tape in the process. ( wish I'd taken a pic of the tape bundle, but at that point I didn't think I'd need your thoughts)
So,,,, any reason not to take the wire clippers to this mess so that I just wind up with wires that go someplace and do something??
Thanks for your time, cheers
p
ID:	120159   Click image for larger version
ID:	120161   Click image for larger version
cjack99 is offline   Reply With Quote
Old 01-26-2011, 05:49 PM   #2
My 88 Excella had a similar bundle of wires. The extra ones were attached to remote sensors on each of the two propane tanks. The sensors detected how much propane was in each tank, and sent signals to the display on the panel above the front window inside the trailer. The sensors had long disapeared, so I stripped out the wires.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 01-26-2011, 06:55 PM   #3
1988 25' Excella
Trumbull , Connecticut
My 88 Excella had a small light fixture attached to the tongue jack. It was suppose to light up the tongue at night for hitching up. It wasn't very bright and was worthless for it's intended purpose. Regards nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 01-27-2011, 04:03 PM   #4
Cjack
cjack99's Avatar
1989 32' Excella
Hurst , Texas
Thanks to the responders! I removed 4 wires going nowhere, along with 3 wire nuts, a pointless in line fuse, and a partridge in a pear tree.
Refurbed the ends of the lp tank fill indicator wires, and sleeved the pair of them and routed them under the tank support, then up the center hold down rod. Lastly, rerouted the remaining bundle and 2 wire nuts so they go under the bracket for the breakaway plug. Result is much nicer, no wires to be seen from the front at all! Just the breakaway plug and the hitch "stuff".
I'm thinking there once was a frame mounted brake controller in there using up most of those wires, I base this on the fact that the 2 remaining wire nuts are involved in the breakaway plug, and the useless wires all ran from these two points, plus a power wire and ground.
Thanks again for the input!!
cheers
mystery, wires
Average hitch height? Chillpoints 1990 - 1993 Excella 3 09-15-2011 01:51 PM
Hitch age? Skater Hitches, Couplers & Balls 18 09-03-2011 01:12 PM
Where does this heavy black wire go? malconium Electrical - Systems, Generators, Batteries & Solar 3 05-31-2011 01:07 PM
Burnt wire on my univolt MonaxLisa Batteries, Univolts, Converters & Inverters 11 03-23-2011 12:31 PM
1989 Airstream Excella 29 Travel Trailer Hensley Hitch eBay Watch Airstreams on eBay 0 01-30-2011 04:50 PM
