Old 08-22-2002, 07:14 PM   #1
1962 19' Globetrotter
2001 31' Excella
Water tank drain
I'm having trouble locating the water tank drain plug (or is it a valve?) on my 78 Excella TT. What does it look like and where do I access it from. Owners manual and service manual aren't clear in describing it.
Thanks.
Craig is offline   Reply With Quote
Old 08-22-2002, 07:21 PM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Craig,
The tank drains are usally a red hose bib type handle that is connected to a brass valve. In your model you should have a black hose poking thru the belly pan in the middle of the trailer. Above this hose there will be a valve handle. This will often be under a kitchen cabinet poking thru the floor. Open it up without the pump on and water in the tank and you should get water out of the drain tube. I suggest if you find more than 1 valve you open them one at a time so you know what is what.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-23-2002, 04:09 AM   #3
1993 29' Excella
Jonesboro , Louisiana
Craig,
My 1977 International did not have a drain valve for the fresh water tank. Instead it had a drain plug. This was accessible via an inspection plate in the belly skin right under the tank. It was about 6 inches square with 4 sheet metal screws holding it in place. When this is removed it reveals a large plastic drain plug that can be unscrewed. Once you drain the tank and get ready to put the plug back, use some plumber's teflon tape to prevent drips.
Good Luck,
James
James Schmidt
29 ft Excello 1000
97 Expedition/Hensley Hitch/
McKesh mirrors
James Schmidt is offline   Reply With Quote
Old 08-23-2002, 06:01 AM   #4
2001 31' Excella
Thanks, James! I think that's where it must be, as I can see the inspection plate.
Old 08-23-2002, 08:22 AM   #5
We have 1978 Excella 500, rear bath and it has no drain for the water tank, only way to empty is to pump it out, my only dislike with the trailer
Ira Iburg is offline   Reply With Quote
Old 08-23-2002, 08:25 AM   #6
2001 31' Excella
Ira,
My Excella owners manual talks about a water tank drain, just doesn't tell where it is. Are you sure there isn't one?
Craig
Old 08-23-2002, 09:42 AM   #7
Just checked my 1978 Excella 500 Owners Manual for winterizing and step 4 instructs me to turn the water pump switch to the ON position to expel water from the storage tank. We use this tank a good bit and this is a pain, it is tight underneath but I brlieve it would be possible to make a drain, think I will try this winter
Old 08-23-2002, 04:49 PM   #8
1993 29' Excella
Ira,
You might want to be sure you don't have a drain plug as described in my post above. It should be easy to see from the underneath side of the trailer. It sure would save a lot of work for you. My trailer was not an excello so it could be different.
Good luck,
James
James Schmidt
29 ft Excello 1000
McKesh mirrors
Old 08-24-2002, 09:02 AM   #9
2001 31' Excella
Ira,
Just checked my Excella 500 owners manual. Check out page 68 when you have a chance (water system section) where the "drain valve locations" diagram is. The diagram shows a drain valve labeled water tank. So I'd be surprised if it doesn't have one. I'm going to check out James advice and will let you know what I find.
Craig
Water leak from Holding Tank Drain gwilliam Fresh Water Systems 5 04-18-2010 06:45 PM
New clean water tank silver suz Fresh Water Systems 19 03-29-2004 08:16 PM
fresh water tank filling system nickcrowhurst Fresh Water Systems 5 03-16-2004 12:37 PM
How cold for winterizing? ipso_facto Our Community 27 12-03-2003 04:56 PM
White water tank drain ramoore53 Fresh Water Systems 4 05-01-2002 10:08 AM
