Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella 500 > 1978- 1979 Excella 500
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 08-13-2002, 08:39 AM
Craig
Profile:
Water Heater
1. Where does the water relief valve on the hot water heater drain the water to (I should say where is it supposed to drain to)? I see no openings in the body near the water heater other than the propane line.
2. My water heater has a black coating on it that looks like some type of protectant. Anyone know what this is?
3. And the really stupid question - the water relief valve on the water heater was stuck (because of the coating mentioned above) fully turned all the way to the left. Wouldn't this be the "open" position for the relief valve to drain water. And turned to the right to close the relief valve? Or do I have this backwards?
Get rid of these ads... register today, it's FREE
Old 08-13-2002, 08:49 AM
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Lower Middle, Tennessee
I have an Atwood in my '77 Excella. It has the same style relief valve my water heater in my house has. When I pull up on it, water flows out. Water then hits the bottom of the heater opening and goes to the ground. This is on the outside of the trailer with the door open of course. Do you have a different style of water heater?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-13-2002, 09:51 AM
83Excella
83Excella's Avatar
Profile:
Water heater pressure valve
The pressure relief is on the outside of the trailer on the water heater and should vent to the outside of the trailer you wouldnt want that hot water going to the inside. The valve should be tested for operaton every so often to be sure it works, you just pull on the small lever on the valve, it is a spring loaded valve set to open at a specific pressure or temerature.
John
Old 08-13-2002, 11:12 AM
Craig
Profile:
Sorry for the confusion. What I intended to refer to was the water drain valve. Isn't there a drain valve on the water heater?
Old 08-13-2002, 08:58 PM
83Excella
83Excella's Avatar
Profile:
water heater drain plug
That too is on the outside, it is a 7/8 hex plug either plastic or aluminum, some water will remain in the tank with the plug out.
Old 08-14-2002, 04:01 PM
davidz71
davidz71's Avatar
Some RV shops sell a water drain valve made of brass which resembles the drain valves on auto radiators.
Craig
AIR #0078
3.73 rear end
Old 07-13-2007, 11:29 PM
KeithC
Profile:  1968 24' Tradewind
Mansfield, Georgia
The "winterization" section of your hot water manufacturer's owner's manual explains the pressure relief valve operation and how to properly clear the pressure valve and blow out all remaining water from the system manually.
Old 10-01-2007, 05:16 PM
Safari-Rick
U.S.Navy Retired
Safari-Rick's Avatar
Profile:  2005 25' Safari
Lakewood, California
Anyone have or had a problem when they replaced the drain valve on the water heater with it leaking. I've tightened it short of breaking the threads and it has this minute leak (drip, drip,drip).
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
vB code is On
Pingbacks are On
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
Water Heater Leaking Outside overlander76 Water Heaters, Filters & Pumps 8 11-02-2003 03:11 PM
Water Heater Advice! John Sims Water Heaters, Filters & Pumps 1 06-16-2003 08:43 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
