Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella 500 > 1978- 1979 Excella 500
Old 07-29-2006, 02:08 PM   #1
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Thumbs up Toilet water saver upgrade
Finally got around to installing a "water saver" kit on the Thetford toilet. This is a kit from the Thetford factory that adds a spritzer hose to the existing fixture so that it can be flushed with less water. This saves on fresh water and on black water capacity for boondocking. It costs about $40 from Thetford (part#08993). Installation is pretty straightforward: Remove two nuts and the water supply from the toilet, remove and invert; Install the water saver kit using supplied clamps (need spring clamp pliers); and reinstall toilet using the new seal from the kit. The spray head mounts on the wall behind or beside the fixture. Been meaning to do this for several years. Excellas had this as an option, but ours came without. One might consider this as putting a diamond in a goat's a--, but I think it may actually prove useful?!
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 10-29-2006, 05:49 PM   #2
nvestysly
nvestysly's Avatar
Profile:  1992 29' Excella
Metro , Atlanta
Our '92 Excella has the water saver but I don't understand how to use it. I find the hose useful when I need a little extra water to clean out the bowl. How do I use it to save water? If I push the flush valve to open the drain it seems water just pours on in. Is there some operation / procedure I don't understand? I cannot just press the "open" valve - when I press this (the big pedal) the water automatically presses at the same time. Am I missing something?
Lucius and Danielle
AIR#25 WBCCI#16771
'92 - 29' Excella
'96 - GMC C2500 Suburban
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 10-30-2006, 05:50 AM   #3
nvestysly
nvestysly's Avatar
Metro , Atlanta
OK... I Think I Understand
After giving this some more thought I think I understand but I'm still not sure it's a "water saver." When I depress the large pedal the toilet valve opens to the black tank while simultaneously flushing water into the bowl (via the small pedal). If I simultaneously use the water saver hose the water is diverted to the hose rather than going through the normal flush cycle.
Said in another way, flush water is diverted to the water saver whenever the water saver is in use. Am I right? Or do I still need to be taught how to use this darn thing? I do not have any instructions and I was not able to find any on Thetford.com or Airstream.com
Lucius and Danielle
AIR#25 WBCCI#16771
'92 - 29' Excella
Old 10-30-2006, 06:31 AM   #4
Auretrvr
Auretrvr's Avatar
Profile:  Iowa City , Iowa
Do you really use the water saver?
We are shopping for a new loo. Our old Galaxy has the water saver which we haven't really used. If we are boondocking, I plan to capture shower/grey water to flush with. (Found a storage bin that just fits our shower with plenty of room to stand in.) Just wondering if the sprayer is worth it or is it just one more thing to leak?
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 12-25-2006, 11:31 PM   #5
Excella CM
Excella CM's Avatar
Venice , California
The instructions for the "water saver" say to hold down the button on the spray head held over the bow and then step on the flush pedal. All the water then goes through the spray head to clean the bowl. If you let up on the spray button water diverts to the bowl rim.
toilet doesn't hold water.... Chuck Sinks, Showers & Toilets 12 10-08-2002 10:03 AM
Toilet valve problem Charles Q Treichel Sinks, Showers & Toilets 1 09-04-2002 10:59 AM
Black water problems Rob Waste Systems, Tanks & Totes 3 08-31-2002 07:34 PM
Water filter system 53flyingcloud Our Community 2 07-05-2002 04:43 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
