Old 04-03-2006, 09:36 PM   #1
1978 31' Excella 500
Slidell , Louisiana
Skin Repair or Replace?
I have a dent on my lower entrance door below my Excella stripe (curbside) which extends several inches to the panel rear of the door next to and above the furnace vent. I talked to a service center nearby who said they would overlay the lower door panel and replace the entire lower curbside panel.
I would like to repair this so I can polish the skin but I don't want leaks.
I have even considered installing a small dummy door covering the furnace exaust dent.
How is the best way to fix this? Will the little dings and dents be very obvious once polished?
Thanks for your thoughts,
Mark
1978 Excella 500 Rear Twin Center Bath
2006 F250 Powerstroke Diesel Crew Cab FX4
Tow Command Factory Brake Controller
MarkExc500 is offline   Reply With Quote
Old 04-04-2006, 01:12 AM   #2
1992 34' Limited
Falls Church , Virginia
Dings and dents obvious? You bet!
Mark -
My observation is that when things are made shiny, ALL flaws become HUGELY obvious. Think of that '56 T-bird, '48 Lincoln, ( or your favorite vehicle)!
ALL blemishes become more pronounced with a high gloss surface. It has to be PERFECT to be perfect!
I saw this more than a lot when I did the show circuit with a '62 Lincoln I used to own in a previous lifetime. There were lots of cars and owners! that would have been a lot better off with original condition finishes.
Have you ever seen that episode of "Antiques Roadshow" where the guy says - 'if this had the original finish/ patina, then it would be worth...."???
Just remember that this opinion is worth EXACTLY what you paid for it.
Axel
SilverToy is offline   Reply With Quote
Alum. Skin Repair 74Tradewind Ribs, Skins & Rivets 16 07-20-2018 01:55 PM
Least expensive repair thenewkid64 General Repair Forum 5 09-23-2013 08:49 AM
Dash Repair Questions JW84345 Airstream Motorhome Forums 15 07-15-2012 08:59 PM
Bed Glide Repair Tamara General Interior Topics 16 08-31-2006 08:28 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
