Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella 500 > 1978- 1979 Excella 500
Old 11-11-2006, 08:31 PM   #1
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
I rerouted that in the sidewall under the sink which allowed a full 4" vent, instead of the factory 2" under the shower pan.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 11-14-2006, 01:47 PM   #2
Profile:  1979 31' Excella 500
Detroit Area , Michigan
Images: 41
Did you have to remove the oven (or maybe there isn't one in your trailer) before installing the new furnace? Mine is right below the oven (1979 31' International).
wacnstac is offline   Reply With Quote
Old 11-18-2006, 02:57 PM   #3
Round on both ends
SafeHarbor's Avatar
1975 28' Argosy 28
Rutledge , Georgia
Hi, Wacnstac,
One MIGHT do it without removing the oven, I guess, but it's much easier access with the oven, the bottom closeout panel, and the lawn chair cabinet liner removed.
Removing the oven is EASY. There are four screws into the countertop and one gas line to remove. Then the oven slides forward until clear of the fuel line. I actually bought this oven new-old-stock in the factory box on Ebay. I paid as much as I would for a modern oven, but it appealed to me to have a brand new 25-year-old stove.
This installation is still in progress, by the way.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 08-22-2007, 09:36 AM   #4
Images: 41
Would there be anything "Wrong" with using the external shell from the old furnace with the one modifcation of cutting out a hole on the bottom for the gas line, to house the new furnace and make things line up in terms of ducts a little better?
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 08:17 PM
31' Excella 500 davidz71 1977 Excella 500 5 06-28-2007 10:15 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 06:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 10:59 PM
78 Excella 500 davidz71 Our Community 2 10-17-2002 02:11 PM
