Old 03-18-2016, 06:23 PM   #43
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
Originally Posted by SpitFireRX View Post
12v Fuse Panel installed to its permanent location,
Very nice! I've never seen that fuse panel before; do you have link of where to purchase?
In our remodel I ended up moving all the 12v wiring from that front panel area to the bedroom area to be closer to the 120v breaker box and so I could put a couch where the old panel was located.
trekerboy is offline   Reply With Quote
Old 03-24-2016, 01:58 PM   #44
SpitFireRX's Avatar
Florida , Florida
It's from vintage trailer supply, http://www.vintagetrailersupply.com/...-p/vts-146.htm
SpitFireRX is offline   Reply With Quote
Old 03-24-2016, 02:12 PM   #45
SpitFireRX's Avatar
Florida , Florida
Some of the most recent tasks.
Removing some of the few remaining interior panels, peeling vinyl off then removing the glue.
Not a fun process
ID:	259306   Click image for larger version
Old 03-28-2016, 11:58 AM   #46
SpitFireRX's Avatar
Florida , Florida
More insulation! More cleaning up interior panels!
New on/off switches on a new piece of aluminum. Got to Fix the door handle and locks as well as wire them before i button it up.
Name:	2016-03-26 19.53.06.jpg
ID:	259481   Click image for larger version
Name:	2016-03-27 12.15.52.jpg
Name:	2016-03-27 12.15.35.jpg
ID:	259483   Click image for larger version
Name:	2016-03-27 13.11.04.jpg
Name:	2016-03-27 13.19.28.jpg
ID:	259485   Click image for larger version
Name:	2016-03-27 15.15.04.jpg
Name:	2016-03-27 15.33.04.jpg
Old 03-31-2016, 02:27 PM   #47
SpitFireRX's Avatar
Florida , Florida
My AS is missing the interior handle on the grab bar lock.
Would this Handle work? interior Side of the Grab handle lock. http://www.vintagecampers.com/viewpart.php?partID=586
My AS https://youtu.be/ubLUKTB3TeU
What the handle looks like http://airstreamsupply.com/New-Airstream-Parts/Doors-and-Locks/Handles-and-Hardware/handle-grab-w-lock-hole-door-bell-socket-380885
Old 04-11-2016, 11:34 AM   #48
SpitFireRX's Avatar
Florida , Florida
OH and before i list this week's activities last week i replaced my 7.5AH test battery with a new Duracell 75AH and i haven't even been able to get it below 100% 12.6v
Only have 3 Fantastic fans and a few LEDS so not very much draw, my 100w panel is more than enough for this right now.
Another weekend has gone by and more has been done!
Sealed the frame to rear C channel connection. then secured it. should have done this a while ago.
Got the door handle and lock cleaned up and riveted back on. Ended up buying a new lock core and reusing internal lock components.
Removed the over the door light housing, replaced the rusted light bulb socket with a different one i had. Refinished the exterior, and cleaned, primed and painted the interior of the housing white to better reflect light.
Got my 3 on/off switches wired up and working.
Finished up some wiring and insulation for final prep before the interior skin goes back on.
Also cleaned up and got the Airstream name plate & put back on. Did some sanding and repainted the back of the plate black to prevent corrosion.
whew
Name:	2016-04-04 13.17.04.jpg
ID:	260477   Click image for larger version
Name:	2016-04-09 19.02.35.jpg
Name:	2016-04-10 13.50.22.jpg
ID:	260479   Click image for larger version
Name:	2016-04-10 17.12.43.jpg
Name:	2016-04-10 17.12.51.jpg
ID:	260481   Click image for larger version
Name:	2016-04-10 18.27.48.jpg
Name:	2016-04-10 18.27.55.jpg
Old 04-11-2016, 11:51 AM   #49
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Nice work! I think of myself as being fairly handy but these DIY rebuild threads are really impressive and appear to be above my pay grade.
Cheers,
John
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 04-11-2016, 01:01 PM   #50
SpitFireRX's Avatar
Florida , Florida
Here's a before of the door light, door handle (the horror) and name plate
Name:	2014-10-04 10.17.01.jpg
Old 04-19-2016, 10:36 AM   #51
SpitFireRX's Avatar
Florida , Florida
Got another large interior panel peeled, cleaned and riveted back in place.
Heres a Video Walkthrough! Excuse the mess
Old 04-20-2016, 05:21 AM   #52
trekerboy's Avatar
You're making great progress! What are you using to strip and clean the interior panels?
Old 05-04-2016, 01:12 PM   #53
SpitFireRX's Avatar
Florida , Florida
Jasco paint and epoxy remover to get the vinyl to bubble up and xylol to remove the left over adhesive. Both very nasty stuff you have to take care to protect yourself. But I wouldn't recommend anything else for the task. It's a difficult dirty time consuming process
Old 05-04-2016, 01:21 PM   #54
SpitFireRX's Avatar
Florida , Florida
Just plugging away here, couple more panels put back in. All but one large panel has had the vinyl removed.
AC 30amp receptacle, distribution box, breakers, and relay switch arrived. Now how do I wire that up again LOL
Also drawing up kitchen designs,
ID:	261877   Click image for larger version
ID:	261879   Click image for larger version
Old 05-18-2016, 11:56 AM   #55
SpitFireRX's Avatar
Florida , Florida
Florida now has officially become hell for the summer with Temps reaching their peak of 96+ (in the trailer) by 11am
Wish i had a awning! Curse who ever decided to remove the one off my trailer!
Thinking of getting a trailer Shelter covering.
Anyway... Got the 30amp Receptical installed, took a while to make sure it was level but not difficult at all. Still got to wire it up.
Started treating the wood that i will be using for the kitchen and wood wall. Maybe this weekend i will have most of the kitchen frame complete.
Name:	2016-05-08 15.22.39.jpg
ID:	262725   Click image for larger version
Name:	2016-05-08 15.58.03.jpg
Name:	2016-05-14 18.45.27.jpg
ID:	262727   Click image for larger version
Name:	2016-05-14 18.45.06.jpg
Name:	2016-05-15 12.43.24.jpg
Old 05-23-2016, 04:51 AM   #56
trekerboy's Avatar
Wood wall, sounds like a cool design idea!
1977 Excella 500 Coastal Camper :: 1977 Airstream Excella 500 Excella77 Airstream Registry Discussions 0 08-23-2014 02:18 PM
'74 Excella Rebuild - The new chassis DanielB 1973-1974 Excella 500 359 11-04-2013 02:02 PM
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 5 03-21-2013 02:32 PM
