Old 03-04-2015, 06:10 AM   #15
1981 31' Excella II
New Market , Alabama
How you going to get the steel bar out to put the frame back together?
Perry
Old 03-05-2015, 03:33 PM   #16
SpitFireRX's Avatar
1979 31' Excella 500
Florida , Florida
We'll see going to try some more PB blaster now that its exposed, I've read i can use a L bracket too
SpitFireRX is offline   Reply With Quote
Old 03-31-2015, 09:28 AM   #17
SpitFireRX's Avatar
Florida , Florida
Things have been moving along here, I've got everything I need for the Windows except tint. But I think Im tinting the interior window to avoid having to open them up again if the tint bubbles down the road.
I also received the steel I need to repair the rear on the 25th. Over the weekend I was able to weld in the two new rectangular tubes that run through the middle of the floor. Two eight foot sections of it, now I'm wondering if I should just replace the entire rail front to back. I guess I'll see as I move forward but I'm 75% sure it's solid add I can see paint instead of rust.
Planning on replacing the main C channel this weekend hoping for cool weather.
ID:	235269   Click image for larger version
Old 04-12-2015, 11:57 AM   #18
SpitFireRX's Avatar
Florida , Florida
Got the two tubes and the C channel welded in Next up will be U/C/J channel replacement and outriggers. Then painting the painting/treating the frame.
Can someone help me confirm the correct Channel i need? The straight U channel for the Rear will be easy enough to find. What i need is this #100968 is straight #104463 is curved but marked Narrow body? E31 A 9 J is the beginning of my vin and does not indicate Wide Body. mine should be 8ft wide or just under.
the straight one im fairly sure will work but will the curved?
Channel Floor Molding 16ft Piece100986 [100986] - $69.92 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Floor Channel Bow - Narrow Body104463 [104463] - $58.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Old 07-13-2015, 05:10 PM   #19
SpitFireRX's Avatar
Florida , Florida
TIME FLIES!
Whew! 3 months since my last post. Got Married in June so i was pretty busy for a while.
Received the replacement floor channels and rear banana wrap from odmrv.com
Got the rear out riggers replaced
Wire Brushed & Acetone frame
Treated rear frame with rust converting solution,
Painted rear frame with first coat of Por-15 last night, took 2.5 hours for 1 coat!
Doing all of this in Florida Summer is not fun, tried to wear shorts on Saturday and within 15 min i scratched up my calf pretty good.
Currently mulling over my choices of plywood (Marine or CDX) and sealants. Thompson's water seal/Expoxy/Timber oil and or oil based paint for the edges.
I know this is personal preference but any tips/comments are welcome.
Old 07-13-2015, 05:49 PM   #20
SpitFireRX's Avatar
Florida , Florida
Pics
Name:	2015-07-13 19.18.26.jpg
ID:	242892   Click image for larger version
Name:	2015-07-13 19.19.07.jpg
Name:	2015-07-13 19.20.28.jpg
Old 07-27-2015, 12:54 PM   #21
SpitFireRX's Avatar
Florida , Florida
Well i got into a big car accident on the 23rd, both vehicles involved rolled and are totaled. No broken bones or stitches but some bad whiplash. (Stop signs are important people!)
Sad that my Van is gone, took alot of money and time to get that thing fixed up. hopefully i can get back to working on the trailer soon.
Old 07-27-2015, 03:54 PM   #22
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Sorry to hear of the accident but glad you're ok.
Old 08-05-2015, 04:03 PM   #23
SpitFireRX's Avatar
Florida , Florida
Got a window finished
Old 09-16-2015, 10:04 AM   #24
SpitFireRX's Avatar
Florida , Florida
Buck Riveting!
My Wife Jessica did a great job!
Name:	2015-09-15 16.13.19.jpg
ID:	248212   Click image for larger version
Name:	2015-09-15 18.51.33.jpg
Old 10-05-2015, 11:41 AM   #25
SpitFireRX's Avatar
Florida , Florida
Getting allot done! Humidity wasn't 99% for once lol
New C channel installed, Cardboard template to thin plywood template to subfloor cut and treated. Next up painting the edges of the subfloor.
Also almost done with 2 windows just the weather seal left.
More coming soon,
ID:	249744   Click image for larger version
Old 11-02-2015, 08:24 AM   #26
SpitFireRX's Avatar
Florida , Florida
Put the rear window back in place after replacing the weather seal. Now that all 4 rear windows have been redone i got the rear subfloor in position, one more inch forward and it will be perfect.
So much to do so little time!
ID:	251538   Click image for larger version
Old 11-11-2015, 10:59 AM   #27
SpitFireRX's Avatar
Florida , Florida
Man was it HOT last weekend, felt like august need to do my cold front dance.
With some help was able to get the Subfloor in position! Feels good also starting to redo a 5th window.
Removed another section of C channel and did some sanding of the corrosion that i exposed.
Also seeing if i can salvage the fabric on the rear awning.
Name:	2015-11-09 14.08.46.jpg
ID:	251916   Click image for larger version
Name:	2015-11-09 14.09.24.jpg
Old 12-07-2015, 10:57 AM   #28
SpitFireRX's Avatar
Florida , Florida
Things continue to move forward, the heat finally broke which is nice.
Section 2 of the subfloor has been done, Additional Floor Channel removed and new sections installed.
ID:	253485   Click image for larger version
Name:	2015-11-09 14.08.30.jpg
Name:	2015-11-27 17.12.41.jpg
1977 Excella 500 Coastal Camper :: 1977 Airstream Excella 500 Excella77 Airstream Registry Discussions 0 08-23-2014 02:18 PM
'74 Excella Rebuild - The new chassis DanielB 1973-1974 Excella 500 359 11-04-2013 02:02 PM
Excella vs Excella II vs Excella 500 vs Excella 1000 ElCamino Man Trailer Values 5 03-21-2013 02:32 PM
