Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Excella 500 > 1978- 1979 Excella 500
Old 10-21-2017, 07:44 AM   #1
Reidsville , North Carolina
78 Excella Low Point Drain
Is there a low point drain for the fresh water tank on my 78 excella 500? I have looked under it several times and can't find anything. It's rear bath if that helps.
bombard16 is offline   Reply With Quote
Old 10-22-2017, 06:50 AM   #2
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Nope. Only way to drain fresh water tank is via the water pump.
4RXLA is offline   Reply With Quote
Old 07-01-2018, 08:07 PM   #3
1978 31' Excella 500
Beach , North Dakota
Not sure if you still need help or not, but my 78 has a little door in the metal. It is right between the tires on the driver side. I pulled the original plug and installed a 1-1/2 (I think) pvc threaded plug, with the square "nut" going into the tank.
Nhegel is offline   Reply With Quote
Low point drain petcock spins TROPHYJIM2 Winterizing, Storage, Carports & Covers 3 10-02-2011 07:47 AM
Can't locate low point drain values MR AIRSTREAM Winterizing, Storage, Carports & Covers 0 09-15-2011 08:57 AM
Low point drain petcocks Larry C Plumbing - Systems & Fixtures 3 04-07-2010 08:53 PM
Replacing the low point water drain valves thecatsandi Fresh Water Systems 4 02-17-2009 11:32 AM
Failure of low point drain valve? desidou Fresh Water Systems 8 12-24-2006 08:29 AM
