Go Back   Airstream Forums > Airstream Marketplace > Commercial Listings
Old 10-13-2018, 09:05 AM   #1
Dan@LED4RV's Avatar
Denton , North Carolina
word to the wise on step light
This light is No Longer Available NLA from any source I can find. and I have looked!
Once the distributors ran out I looked into the company that supply s them and they have gone dark. They are not on the web where they use to be.
The lens is NLA also.
I suggest anyone who has this fixture, and there are many, to check the lens and see if it is loose. If it is loose it will fall out at some point. I would suggest getting some clear silicone and putting a lite bead around the lens to attach it to the light fixture. I suggest enough so it will stay in and little enough so you can get it off if you need to.
I have a friend who did a work-around with some plastic. I guess this something others will have to do at some point. This light is on MANY Airstream units.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 10-13-2018, 09:33 AM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I bought several lenses earlier in the summer $9, I bought all they had.
Found more at the factory store, including the complete assembly.
There are a few places that carry them but supplies are drying up.
Additionally, if your lens has yellowed, wet sanding with 4000 grit paper will clear them up. Followed with liquid polish they will become new again.
Old 06-25-2023, 05:21 PM   #3
Ol Bob's Avatar
2006 34' Classic S/O
1994 28' Excella
1950 19' Globetrotter
Elgin , Texas
Somebody should make these.
There are thousands of Airstreams that need them.
All The Best...
'Ol Bob
Ol Bob is offline   Reply With Quote
A word to the wise Photobum Tires 12 05-23-2017 10:04 PM
New owner of '69 Land Yacht 25' needs help from wise airlovers Airgirl1 General Repair Forum 8 05-07-2012 08:44 AM
Two Wise Ones Head East! Two Wise Ones On The Road... 3 04-21-2008 06:15 PM
