Old 04-05-2019, 01:29 PM   #1
Dan@LED4RV's Avatar
Denton , North Carolina
Upgrading to LED Teardrop marker lights
Hey guys, I have taken the time to do a video with a plan for upgrading or replacing the LED teardrop lights. As you know products get upgraded, they go NLA. Then comes the challenge of figuring out what light can be used where. Airstream has gotten their supplier to make some changes to the way they are mounted because they do not want the plastic bezel touching the skin. This video talks about this concept for what light goes where and if it needs a gasket or not. This plan allows for using these LED lights where in the past the incandescent s were all that were used. Like the Amber on the top front panels. Airstream has never used the LEDs there but the older incandescent they did. Thus Airstream does not carry that part, nor do their dealers.
Here is the video I did
https://youtu.be/ypR99OYoL14
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 04-05-2019, 02:05 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Thanks Dan. I wish I knew you had these a month ago. I just replaced mine.
Here is the blog post
http://www.airforums.com/forums/blog...lacement-3015/
Dept of “OverKill”
Old 04-06-2019, 05:45 AM   #3
Dan@LED4RV's Avatar
I wish too
Great job!!! I really like the extra silicon to seal the lights on the back.
Dan Brown
Denton NC
Old 04-06-2019, 07:27 AM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Now I know...
My last set leaked. I’m not sure that thermo weld holds up over time. I thought it worth a try
Disclaimer: During the installation of these lights “NO” silicone came in contact with the skin of my Airstream.
Dept of “OverKill”
Old 04-06-2019, 07:58 AM   #5
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Lights
Where is everyone buying these lights??
Old 05-09-2019, 07:27 AM   #6
Dan@LED4RV's Avatar
lots have been getting them here
Below are the links
Teardrop Clearance Light 10 Amber LEDs wL Gasket SKU2347
Teardrop Clearance Light 10 Red LED wL Gasket SKU2348
Straight Base Amber 10 LED Teardrop Marker Light sku2395
Straight Base Red 10 LED Teardrop Marker Light sku2396
Straight Base 3 Wire Amber 10 LED Teardrop Marker Light sku2397
Once again here is the video that talks about it.
Dan Brown
Denton NC
Old 05-09-2019, 09:06 AM   #7
Apopka , Florida
I have a 2013 25 FC. Can you suggest what lights I need? Also, may I suggest a video showing how to change one of these lights to your product.
rfequity is offline   Reply With Quote
Help to Install new teardrop LED marker lights Air-Texas Lights - Interior & Exterior 19 03-21-2012 10:51 AM
Installing 1959 front and rear teardrop marker lights JimHoek Lights - Interior & Exterior 8 09-04-2010 09:06 AM
VTS Repro teardrop marker lights- what's the deal? PA BAMBI II Lights - Interior & Exterior 3 08-29-2010 10:08 AM
LED Running/marker Lights-Teardrop BornToRock Electrical - Systems, Generators, Batteries & Solar 2 12-18-2006 12:46 PM
