Old 10-04-2010, 03:39 AM   #21
1967 17' Caravel
1979 28' Airstream Excella 28
Wheat Ridge , Colorado
[QUOTE=2airishuman;901967]nice thread bret
are you suggesting they use a DIFFERENT frame mfg for these 1 off units?
_______
These are Dexter chassis. They aren't one-off builds but they aren't available as an option on travel trailers nor will they be coming to a dealer near you.
________
i like the idea of a beefier frame, obviously the axles are rated appropriately...
so in this unit that would be 6,500 lbs each?
________
The beefier frame comes with a higher base weight, 6500# axles, the appropriate coupler capacity, and a very stiff ride until it is properly loaded.
__________
does a/s do any shell reinforcements related to your spec/needs?
are more ribs or strategically placed ribbing used?
__________
The bodies are 23' standard or front bedroom units depending on where our client needs the entry door. For the factory to install ribs in any non-standard location would be very inefficient since the wall panels are built in specific jigs. It is not all that efficient to leave off parts, such as windows, since our vehicles have to flow through each work station on the production line until they reach the water test station where they exit the building. We install additional ribs (standard factory or our extra heavy ones) per our engineers' designs. We also install headers across large openings and heavy aluminum backers for the later mounting of exhaust hoods and fans, overshelves, A/V equipment, etc.
__________
do they do ANYTHING extra to the frame/shell connection?
__________
No. The standard bolts are installed through the wing beams, flooring and wall channel. We sometimes separate the body from the chassis, remove the plywood floor and replace it with 1/4" aluminum deck plate (depending on the order and the budget). When we do so we go back in with stainless bolts and nuts and insulate the floor panels from the steel chassis to prevent corrosion. Basically, we ignore any structural strength the body may add to the overall trailer structure. Because of the major modifications we make to the body we essentially use the chassis as a platform trailer to carry our load plus the weight of the body.
___________
or is everything related to the shell for these commercial units done in your shop?
___________
The process is very similar to ordering a livery or funeral car. You can't walk into your local Lincoln or Cadillac dealer and buy a stretch limo or a hearse. Ford or GM builds cars specifically for these markets and sells them only through a couple of custom coach builders. In our case, most units are one-offs with very little repetition due to meeting individual customer requirements.
thanks for sharing the pics!
______________
You are most welcome. It is part of the fun of being in this unique business!
Brett Hall
Wheat Ridge (Denver) Colorado
http://www.TimelessTravelTrailers.com
Brett - TTT is offline   Reply With Quote
Old 03-17-2011, 12:49 PM   #22
Images: 51
Promotion Trailer built for Velamints- by the Trailer Company Florida
J M Reed is offline   Reply With Quote
Old 03-17-2011, 01:01 PM   #23
This was done about 10 years ago.
The Snapple Conversion
What this is all about is "gettin' your hair dyed" some very different and very rainbow colors! The Snapple Man goes from event to event, setting up with other booths and quickly becomes one of the main attractions. A quick visit to his converted Airstream and he'll color you hair for you -- and the color will be your favorite Snapple color! We hear tell he was just in Long Beach, California and recently was on the lot of Merv Griffin Studios. What a guy! Thanks, Mr. Snapple, for letting us show off your very colorful and perfectly wonderful adaptation!
Old 03-17-2011, 02:33 PM   #24
Oops.
custom airstream, customization, denver, timeless travel trailers
Timeless travel trailers Aerowood Off Topic Forum 21 05-05-2011 11:40 AM
Timeless builds winter tour trailer for Eddie Bauer Brett - TTT Commercial Listings 9 03-21-2010 12:18 AM
Timeless Trailer Garage Sale Aerowood Off Topic Forum 15 07-23-2009 07:47 AM
Any references for Timeless Trailers in Colorado? 60traveler Interior Restoration Forum 3 04-29-2008 12:19 PM
