Go Back   Airstream Forums > Airstream Marketplace > The Vendor's Forum
Old 02-27-2004, 09:59 AM   #1
pbt45
Profile:
Re-insulation
Hi,
Is there any way to re-insulate a 40 year old Airstream
effectively? We live in Castle Rock, Colorado.
Thank You,
Bob & Carol
PBT45
pbt45 is offline   Reply With Quote
Old 02-27-2004, 10:25 AM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Howdy Neighbors! Welcome to the Forums ~
The most effective way I know of is a lot of work...removing the interior panels and placing new batts between the skins. Same thing with the floor, but you take off the belly pan. If your floor is "bad" you can fix this at the same time...
There have been some discussions here about using spray-in-foam-type insulations, you may want to perform a search through old threads using "insulation" as a keyword.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
InsideOut is online now   Reply With Quote
