01-22-2017, 01:09 PM
Electronic Controls OEM
Allentown
, New Jersey
Micro-Air Discount Offer
Okay everyone. The reception and interest here has been so outstanding, Micro-Air is going to extend to all of you an special offer that we have done for some other trailer owners forums. I have just created a special coupon code that you can enter into our webstore if you decide to make a purchase. The coupon will save you $25 on the EasyStart 364 model, and an equivalent percentage on the EasyStart 366. During checkout on the payment page, just enter AIRSTREAM (case sensitive) into the coupon code box. You will see the discount applied on the next page before order confirmation and submission.
Thank you again for the kind reception, great questions, and interest in our EasyStart product line.
01-22-2017, 02:41 PM
2015 28' Flying Cloud
Newtown
, Pennsylvania
Just ordered 2. Thanks.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
400ah LiFePo4, 800 watts solar, 2x eu2000i Propane
PD9160 converter, Prosine 1800 inverter
2x Victron 100/30 Smart Solar, Victron Smart Shunt
01-23-2017, 06:23 AM
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
Ordered one. Won't do install until spring.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
01-23-2017, 09:29 AM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
I rarely turn down a cup of coffee so that's good. How long is that code good for? I'm thinking I'll climb on the roof soon and have a first hand look at the AC unit before I commit.
But this certainly sounds like something worthwhile.
@living.somewhere.yonder | Instagram
01-23-2017, 09:37 AM
Allentown
, New Jersey
Originally Posted by SCOTTinNJ
How long is that code good for?...
...But this certainly sounds like something worthwhile.
Thank you, and we're glad to hear that! The discount code will stay valid at least through the summer. We realize that everyone won't likely get around to considering this until the weather warms up.
01-23-2017, 09:41 AM
2014 30' FB FC Bunk
Anywhere
Great. It's 40 degrees with 30 mph winds as I type. Not going on the roof!
01-26-2017, 09:59 PM
Journeyman
2016 25' International
Amherst
, Massachusetts
Ordered one. Thanks Matteo.
02-08-2017, 01:31 PM
2011 20' Flying Cloud
Lemont
I just ordered one. Matteo was very helpful.
Although my Attwood Air Command does 13500 does work as advertised with one Honda 2000i generator, the Honda has to running full-on, (no ECO-mode).
With this unit, I'll be able to start the AC in ECO-mode, which should produce less strain on the AC and generator, plus (hopefully) give me an all-night run time. It might even be able to charge the batteries while running the AC, but I'm not counting on that... I'll update after installation and testing.
Glenn
02-08-2017, 01:42 PM
Biloxi
, Mississippi
Is there a link? All I can find under this name is an air quality testing company.
MICHAEL
02-08-2017, 01:46 PM
Journeyman
Amherst
, Massachusetts
http://www.microair.net/main/default.html
Coupon code is AIRSTREAM
02-08-2017, 01:48 PM
Allentown
, New Jersey
Sorry, AWCHIEF. You went to www.microair.COM. We are www.microair.NET. You can also go to our webstore at store.microair.net to find the EasyStart 364.
02-08-2017, 02:16 PM
Biloxi
, Mississippi
Matteo, thank you
MICHAEL
02-08-2017, 06:12 PM
2014 30' FB FC Bunk
Anywhere
Glenn
If you can't charge through the converter I wonder if you could at least plug in a 1 amp trickle charger? If you are talking about running it all night you'd get a bit of a charge at least.
02-09-2017, 07:19 AM
2015 30' FB FC Bunk
Ayer
, Massachusetts
Looks interesting, I watched the video but honest I wouldn't trust myself to do that work.
02-13-2017, 12:45 PM
2019 30' Classic
Canfield
, Ohio
I converted to a 4 stage converter/charger and I have manual control on the type of charging. I can trickle charge if that is worth anything. We'll see what happens once my Easystart is hooked up.
I'm waiting for a few warm days here in Ohio to install.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
02-13-2017, 05:04 PM
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
We are thinking of getting a genetator for the Airstream, and it sounds like we should be investigating Easy-Start so we can run up to a 15k BTU by with a 2000W Honda or Yamaha or maybe the 2400W Yamaha genetator converted to propane. Those gens are about as heavy ad I'd want to lift in and out the truck. We'd ideally like whichever generator we get to also serve as backup power for the sump pump at home. The sump pump may require a 3500W to 5000W generator (Locked Rotor Amps of 30A to 40A) to start without an Easy-Start, so the question is:
"Is there an Easy-Start solution that works for a sump pump?"
Joe
WBCCI/VAC #702 & #6768
02-13-2017, 05:14 PM
2017 23' Flying Cloud
Parker
With the IP65 can you mount it on the roof as a stand alone, and will it be fine? Or does it need cover from the AC shroud.
Troutboy
02-13-2017, 05:23 PM
Allentown
, New Jersey
Hi Joe. EasyStart works with any motor that has a split winding. That is, the motor has a "start" winding and a "run" or "main" winding. These motors have 3 wires and are called PSC (permanent split-capcitor) motors. They use either a start cap, or both a start cap and a run cap. The other main type of motor is called "shaded-pole". These only have 2 wires, and therefore are not compatible with EasyStart.
EasyStart has been used with success on many pump motors up to 5HP for air compressors, and up to 2.5HP for watermakers. Wiring EasyStart into these can be very difficult though because the motor connections are not as easily accessible as they are with an air conditioner compressor. But nevertheless, it is feasible.
If you take a photo of your sump pump motor's dataplate, I should be able to determine for you if EasyStart would be compatible.
02-13-2017, 05:30 PM
Allentown
, New Jersey
Hi Troutboy. Although the EasyStart IP65 enclosure can withstand blowing rain and water immersion, its plastic material cannot withstand the UV of direct sunlight for extended periods of time (months and years). Therefore, it should be mounted underneath the shroud of the A/C unit.
02-13-2017, 07:57 PM
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
Thanks for the quick response. Unfortunately, we have a submersible sump pump that sits under water most of the time. Even with a psc motor, only two wires exit the sump pump housing. I don't think I want to break the seal to access internal wires. I guess the best solution will be either a new sump pump with a lower start current or a bigger genetator.
Joe
