Join Airstream Forums Today
Old 01-23-2010, 09:32 AM   #1
LED tail lights # 2
Hot off the press.
We now have LED tail lights for many models, that work with the "tail light monitors".
Will list them in our web site, January 24th, 2010.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-29-2010, 01:38 PM   #2
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
70's A/S taillight
Andy I checked on your site but I guess there is still not an LED fixture that would fit my 1976 Sovereign. Don
adonh is offline   Reply With Quote
Old 01-29-2010, 03:18 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Where is this new red LED tail light, Andy? All I see is the old one.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 01-29-2010, 04:22 PM   #4
Mike.
Same tail light with a little modification to it.
All that needs to be done to continue with the "tail light monitor" system, is to take the plastic end off the fiber optic wire. That leaves the fiber optic end with a brass sleeve on it.
Insert that sleeve into the back of the tail light, push it as far forward as you can, (about 1/4 inch) seal it in place, with Par bond, or Vulkem, or Sikoflex, or whatever you want ot hold the brass sleeve in place.
Mike, since you already have those lights, carefully drill a 5/32 inch, no larger, hole in the dead center of the back of the tail light. The drill will go thru the potting material. Do not hit the lens with the drill bit.
All the bench tests were great.
Mike, call me if you have any questions, but I will not be back in the office until Feb 15th.
Mahalo.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-29-2010, 05:03 PM   #5
adonh's Avatar
1976 31' Sovereign
Andy, will the Part #: 66125 Light tail, LED, 4.25" X 5.5". fit the 70's model trailer. It says for 94's and up.
Old 01-29-2010, 05:15 PM   #6
Sorry, but its rectangular, therefore it will not fit the square holes.
But, I am working on a replacement for the squasre holes.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-29-2010, 05:47 PM   #7
adonh's Avatar
1976 31' Sovereign
Thanks Andy. I see you are going to be out until 2/15. Are you heading down to TX for the Vintage Rally that starts on 2/10 by chance. You have a lot of customers down here. My Henchen axles and Kodiak disc barkes are working great.
Don
Old 01-29-2010, 07:55 PM   #8
Don
Don.
No, as a matter of fact I will be heading to the land of real tall palm trees, where you can be in the shade, while your enjoying a 'Mai Tai" or two.
Aloha.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-29-2010, 07:59 PM   #9
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Don
No, he'll be in Hawaii.
1958 Overlander
4CU 1st VP
Old 01-29-2010, 08:00 PM   #10
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-29-2010, 08:08 PM   #11
startrekker2001's Avatar
1978 31' Excella 500
Palm Bay , Florida
Images: 34
70's led tail lights
Check out my website for instructions on how to install 4" square led tail lights into your 70's era Airstreams.
LED Taillight upgrade
It's simple and the results are great.
Vic Smith
Director Florida State Rally
www.floridastaterally.org
www.facebook.com/FloridaStateRally
WBCCI Florida Unit 027 Trustee
http://www.airstream-adventures.com/...rida_Unit.html
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
LED Tail lights adonh Lights - Interior & Exterior 7 05-10-2010 11:54 AM
LED Tail Lights Inland RV Center, In Commercial Listings 6 01-11-2010 06:47 PM
LED tail lights. outofcontrol Classic Motorhomes 54 01-26-2009 06:35 PM
Led Tail Lights For Classics Et Al vetdr Lights - Interior & Exterior 5 03-01-2007 08:04 AM
7 inch LED tail lights Inland RV Center, In Commercial Listings 0 06-22-2006 05:36 PM
