Old 10-21-2010, 12:58 PM   #1
Dan@LED4RV's Avatar
Denton , North Carolina
LED Dimmers
We now have the LED Light dimmers.
PWM Dimmer 12 volt Knob Controlled, # 12VKDim
PWM Dimmer RF Controlled 12 Volt , # 12VRFDim
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 10-21-2010, 02:33 PM   #2
Ottawa , ON
Pity it's got such an ugly face.
Old 10-21-2010, 04:38 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Dan,
I'm assuming the control can be mounted behind a cover or plywood. Is the knob shaft long enough to go through 1/4" plywood?
On the RF model, can you have more than one installed, and not have them interfere with each other?
Chris
Old 10-21-2010, 06:54 PM   #4
Usually Sleepy
biggoofball's Avatar
East Haven , Connecticut
Images: 14
Really digging the remote control.
biggoofball is offline   Reply With Quote
Old 10-21-2010, 07:15 PM   #5
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
I love this!
bwaysteve is offline   Reply With Quote
Old 10-22-2010, 09:11 AM   #6
Dan@LED4RV's Avatar
Measurements
Originally Posted by Minno View Post
Dan,
Chris
The shaft is 1/2 in. long without the knob. With the knob on, the clearance is 3/16 in. The shaft is tapered so you might need to put a little putty on it to insure you won't loose the knob over time if you wanted to put in behind a a 1/4in. piece of plywood.
Good question. Thanks for asking.
Dan Brown
Denton NC
Old 10-22-2010, 11:37 AM   #7
Minno's Avatar
1972 31' Sovereign
Thanks Dan - that helps me come up with an idea for our trailer.
What about the RF version question? I'm not really interested in a remote control, but others might be and might want to put multiple units in they can control separately.
Old 10-22-2010, 03:05 PM   #8
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Nice - thanks for posting
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 10-23-2010, 06:43 AM   #9
Dan@LED4RV's Avatar
Yes two dimmers will work
Chris,
Sorry it took me so long to get back on here. I did a video so you could see it. Yes you can use the two dimmers in series.
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/K5yNsQJxO-M...</param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/K5yNsQJxO-M?fs=1&amp;hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Dan Brown
Denton NC
Old 10-23-2010, 04:56 PM   #10
Dan@LED4RV's Avatar
I tried to port the video into the previous post but it does not work. The link is in it.
Dan Brown
Denton NC
Old 10-23-2010, 06:17 PM   #11
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by Dan@LED4RV View Post
Chris,
Hi Dan,
The way I interpreted Chris' question was not if you could use two in series, but rather that if you have multiple RF units controlling different LED lights, is there a way to control them individually? That is, can you change channels to keep one remote from interfering with the other LED receiver(s)?
That's my question anyway.
Vaughan
Old 10-24-2010, 09:55 AM   #12
Minno's Avatar
1972 31' Sovereign
Originally Posted by vswingfield View Post
Hi Dan,
Yes, that's exectly what was I was asking.
Old 10-25-2010, 08:04 PM   #13
Dan@LED4RV's Avatar
one remote for two light sets
Thanks guys, that went over me head.
I'll look into one that I can get that will do what your looking for. What I'm reading about it says it will. I'll get back to you on it.
However, I hooked up two of the "PWM Dimmer RF Controlled 12 Volt , # 12VRFDim" controllers and one remote worked both of them at the same time. It also works inside the a wooden cabinet.
Dan Brown
Denton NC
Old 10-25-2010, 10:12 PM   #14
Ottawa , ON
Some devices that use RF to transmit signals for control have tiny DIP switches inside them to alter the code used in order to avoid, say, dimming your neighbour's lights, or vice versa.
Have you had a look inside to see if such is the case with this model? Of course, the transmitter AND the receiver would have to have them.
led
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
LED Conversion shermantic Lights - Interior & Exterior 12 02-14-2009 07:14 PM
LED lights SteveH Lights - Interior & Exterior 22 09-17-2007 10:58 AM
LED on face of A/C Dwight Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-24-2004 09:19 AM
