04-07-2016, 12:17 PM
Denton
, North Carolina
Getting lens out for step light
Hey Folks,
I keep getting asked how you get this Step light lens out without taking the whole fixture out. For someone who does not know, It is so easy it is hard. Please see pictures. sku992 AS#510732-01
Dan Brown Denton NC
04-07-2016, 12:58 PM
2005 31' Classic
Pleasant Plains
I didn't need a screwdriver to remove mine. Just grabbed each bottom side, slid up slightly, and lifted it out of the housing.
Greg & Mary
2005, 31 ft. Classic - 2008 Ford F250
12-28-2018, 05:25 PM
2004 25' Safari
Ormond Beach
Ok, I know Im a little late on this post, but does anyone know where to buy this step light replacement lens 510732-01 ? I have tried everywhere. Out of doors mart theur sold last one in 12/18. No mention of restocking. Thanks
12-29-2018, 08:04 AM
Denton
, North Carolina
No Longer Available NLA
Originally Posted by JMB11
Ok, I know Im a little late on this post, but does anyone know where to buy this step light replacement lens 510732-01 ? I have tried everywhere. Out of doors mart their sold last one in 12/18. No mention of restocking. Thanks
I have looked high and low. No luck. The company just went out of business or stopped making them. No Longer Available NLA
The light itself is metal so it may be you can buff it and paint it. I have seen folks fashion a new lens out of plastic then glue it on. It looked pretty good.
If your problem is with the wire there is a solution
Dan Brown Denton NC
12-29-2018, 08:42 AM
2004 25' Safari
Ormond Beach
Thanks for the reply Dan. My light looks great but the lens cracked when installing new LED bulb. I’ll just make a lens out of glass or plastic. Thank you.
05-08-2019, 01:40 PM
Hunt
Thanks, I got the lens off and the light bulb filament is broken. I am looking for an LED replacement. I was wondering if I use the 4 LED 1.2 Watt replacement for 67 bulb (Bright White SKU588) if I need to do any modifications of the housing for the light? Or, do I just put the LED in where the 67 bulb was removed? Is there anything else to do when replacing the 67 bulb with the above led? no wiring mods, electrical mods?? Seems way too easy. Is this the same with the interior lights on my Bambi? Do you have a good reference article on where to start with going all (or mostly) LED?
05-09-2019, 04:26 AM
Denton
, North Carolina
Nothing else
AirVet
Yes all you need to do is get the 67 bulb out and put the (Bright White SKU588) bulb in it's place. It is a tight fit but no other modifications are needed.
Click here to see the Sku588
If you read the above posted you will find that some folks found it hard to get the lens off and other not so much. Over time this lens becomes lose and if it falls out it is No Longer Available NLA. If you find yours is lose you might want to put a small dap of clear silicon to where it will hold it in and still be able to get the lens back off if you need to.
Dan Brown Denton NC
09-23-2020, 09:22 PM
2005 25' Classic
Guelph
, Ontario
CanAm has them. I replaced mine today.
07-02-2023, 10:19 AM
1995 25' Excella
Yakima
A little late to this party!!
My light and lens are in good shape. My question is what hardware holds the light on? It appears the light is being held in place by the sealer. I have the two holes but nothing in them. Thanks for the help.
08-23-2023, 08:43 PM
1998 31' Excella 1000
Marana
, AZ
step lens
I have 2 step lens(s) if anyone needs a replacement. The thing I was told,the factory that made them in Asia burned down. I have a 31 ft excella 1000 1998. lens looks like the one at the top of this thread.
going to keep one for spare. So if you need one let me know.
cheers
10-14-2023, 12:21 PM
2007 25' Safari FB SE
Sugar Land
Yardleymoon - Sent you a pm via your profile.
Dwight & Ellen + (the Beagles)
2011 F350 SRW King Ranch, 6.7L, 3.55 ELD, Billsteins, Hellwig w/ Reese Dual Cam & 800# bars. 2007 Safari 25 FB SE (stock - well sort of)
