08-09-2014, 05:00 AM
#81
2008 25' Safari FB SE
Medina
, Ohio
I used finials for curtain rods. I used balls. Just drilled a hole in the plastic top and screwed them on. They come with a big screw attached.
http://www.amazon.com/Wood-Finials-D...urtain+finials
Liz, Brian and 3 Yorkies
The Silver Pearl & The Black Pearl
2008 25' Safari FB SE Queen converted to King
2014 Ford Expedition EXP Limited 4x4 V-8
McKesh towing mirrors
Centramatic Balancers
Hensley Swift-Arrow Hitch
08-10-2014, 08:15 AM
#82
1977 Argosy 28
Irrigon
, Oregon
Palmtreegirl, I like that ideal thanks. Got my sandlapper holder installed, now have to finish the poles.
Rod
AIR# 60278
08-10-2014, 08:26 AM
#83
1977 Argosy 28
Irrigon
, Oregon
I could not be happier with the holder, John was great to work with. But if anybody installs one of these on an Atwood jack like mine, beware the tube is not 2.25" it is 2.20".
A piece of galvanized plumbers tape made the perfect shim.
Rod
AIR# 60278
08-10-2014, 08:30 AM
#84
1993 34' Excella
York
, South Carolina
Thanks for posting the picture rod. You may need to swing the jack motor 90* for the center pole to clear. If so, it is easily done by loosening the 3 set screws in the motor collar, rotate the head, then retighten.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
08-10-2014, 08:42 AM
#85
1977 Argosy 28
Irrigon
, Oregon
Thanks John. You can't really tell by the picture but on this jack the motor is on top of the jack, so it has the same dimensions on all four sides. The center pole will clear the jack with room to spare.
Rod
AIR# 60278
08-10-2014, 01:26 PM
#86
1993 34' Excella
York
, South Carolina
Good to know Rod. When designing the holder, I tried to account for as many variations of jack heads/sizes, TV's, lights, tailgates, etc as I could. There is an endless variety of combos. About 99.9% of the time it works great. Some of the newer jacks with the huge motor, and the Classic Limiteds with the horizontal bottles pose a problem.
John
John
08-10-2014, 09:19 PM
#87
1980 24' Caravelle
corpus christi
When looking for a flag pole at lowes found in the pool cleaning supplies 3 piece alum pole 4 feet to 12 feet easy to store and light weight.
08-11-2014, 09:27 AM
#88
2020 Classic 33
Box Elder
, South Dakota
Handy make sure that the diameter is 1 1/8 max otherwise it won't slip through. Some of the multi section poles at Lowe's are to large.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
08-30-2014, 05:07 PM
#89
2014 27' FB International
North Salt Lake
, Utah
Thanks John. Installing the holder was a "breeze" and it works great!
2014 International Onyx 27FB
09-01-2014, 06:19 PM
#90
1993 34' Excella
York
, South Carolina
Thanks for the pic folks, sure looks good. Darn fine trailer you got there.
John
John
02-01-2015, 12:31 PM
#91
1956 22' Safari
apex
, North Carolina
john, I would love one of your 3 flag holders. Can I arrange to purchase? I can be reached at buffetbuster55@gmail.com I look forward to hearing from you.
02-01-2015, 07:16 PM
#92
1993 34' Excella
York
, South Carolina
I'm on it, sending you an email now. Thanks. John
John
03-15-2015, 10:46 AM
#93
1972 23' Safari
Derry
, New Hampshire
Could u send the info on the 3 pole flag unit! Many thanks @ hope to connect on our travels! remdog68@me.com
03-15-2015, 10:55 AM
#94
1993 34' Excella
York
, South Carolina
Sending you an email. For some pix, check post #1.
Thanks.
John
John
08-17-2015, 07:32 AM
#95
Dallas
Order flag pole mount
Can you send me pricing?
Paul@d-e-g.com
08-17-2015, 10:10 AM
#96
1993 34' Excella
York
, South Carolina
Will do. Thanks. John
John
11-24-2015, 07:57 AM
#97
This is a newbie question so please pardon my ignorance! When traveling with your flag holder attached are the flags removed, or tied down, or left to fly?
"Now it's time to leave the capsule if you dare".
11-24-2015, 09:56 AM
#98
2010 28' Flying Cloud
Lower Alabama
, USA
Leave them up and let them fly! Trick is to see how fast and far you can go before the poles are destroyed and your trailer bent up.
Seriously, take the poles out of holder and store poles and flags. The holder is permanently affixed to the jack.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
11-24-2015, 10:53 AM
#99
1993 34' Excella
York
, South Carolina
Yep, gotta tak'em out of the holder.
If you use the hitch pin clip method to attach the flags to the poles as I do, just pull the top pin (leave the pin in the flag grommet), collapse the pole to 6', then simply roll the flag around the pole for transport.
John
12-02-2015, 10:09 PM
#100
sacramento
Please send me pricing thanks
