Go Back   Airstream Forums > Airstream Marketplace > The Vendor's Forum
Old 10-15-2009, 02:17 PM   #1
Commercial Vendor
Profile:  Corona , California
Disc brakes
NOTICE NOTICE
Airstream, according to Larry Huttle, will no longer install disc brakes on any production model trailers.
If you need to or wish to add the disc brakes, to any new or older trailer, we carry complete disc brake kits in stock, that include brackets, steel tubing, Carlisle actuators, Kodiak caliper and rotor kits, along with the proper grease.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-15-2009, 03:20 PM   #2
Profile:  2007 25' Safari FB SE
Juniper Hills , The Great Mojave Desert
I strongly recommend doing this upgrade. I came within literal inches of an accident towing my trailer with it's old drum brakes. I can't describe the feelings of helplessness and dread I had while standing on the brakes and the unit just not stopping. Still get the shivers thinking about it.
That was the moment I decided to do the upgrade.
My brake kit was ordered from Andy by another trailer restorer. Myself and a friend had it done in a day.
My kit had everything and it is a simple procedure requiring a few common tools.
The upsides are that now not only can the trailer stop the truck easily the whole unit stops in about the same distance as the truck alone. Trailer brake fade is a thing of the past too.
Another plus is that the disc hubs are balanced unlike the drum hubs so after you install the disc brakes you can balance your wheels and give your trailer a nice vibration free ride.
The main reason I would urge you to do this if you are on the fence is that if you can stop your rig instead of hitting some fool who blindly pulls out in front of you like happened to me. You will save thousands and thousands in repairs or worse injury to you or a family member.
This is money well spent.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is offline   Reply With Quote
Old 10-15-2009, 03:57 PM   #3
Commercial Vendor
The same situation, or worse, we predict, will happen to owners who down grade the 12 inch electric brakes, to 10 inch electric brakes.
Safety should never be compromized, or it's margin decreased, for the sake of a few dollars savings.
Life is far more precious than a few dollars.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-15-2009, 04:09 PM   #4
Profile:  1985 31' Excella
battle ground, , Washington
new axles with disc's?
say, Andy, can new axles be purchased with disc brake systems on them? and the discs-are they hydraulic? or electric? do the disc's require a surge type of master cylinder?
thanks
wmarsha is offline   Reply With Quote
Old 10-15-2009, 04:45 PM   #5
Commercial Vendor
thanks
New axles are shipped bare from Ohio, and we ship the disc brake kit from California.
Or, we ship the bare axles and the disc brake kit from California.
It depends on what state someone lives in, so as to minimize freight costs.
Shipping axles with rotors mounted on them, is a no no, since the rotors are exposed and could be damaged. Freight lines can be very rough with some items.
We ship the axles on a pallet, with the disc brake parts in boxes, that are fastened to the pallet as well.
Disc brakes for an Airstream trailer, operate from a "brake controller" that's mounted in the tow vehicle.
Disc brakes are controlled by an "actuator" that applies the hydraulic pressure to the calipers. The actuator is powered by 12 volts DC, and is told what to do, and when, by the controller that's in the tow vehicle. The brake controller is activated when you apply pressure to the brake pedal, or manually, any time you may choose.
Surge brakes are an extreme HAZARD for travel trialers, since you cannot apply the brakes "at your command".
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-15-2009, 07:20 PM   #6
Commercial Vendor
vinstream's Avatar
Profile:  1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Airstream (if this is true) should be installing disk breaks as standard! The fact that they are now not even doing it as a option is not good ;( The product line keeps gaining in weight so why would not want the best in safety? Airstream is more worried in west coast coppers (which by the way came with disk breaks) than travel trailers....
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
vinstream is online now   Reply With Quote
Old 10-15-2009, 07:24 PM   #7
serial airstreamist
wheel interested's Avatar
Profile:  2005 28' Classic
Lapeer , Michigan
Images: 117
hi Andy, did Airstream ( through Larry Huttle) say why they are no longer installing disc brakes at the factory?
CJ
The future belongs to those who believe in the beauty of their dreams.-Eleanor Roosevelt
It is never too late to be who you might have been.-George Eliot
wheel interested is offline   Reply With Quote
Old 10-15-2009, 07:28 PM   #8
Commercial Vendor
No he did not.
But I happen to know that they had way too much trouble with whatever they were doing with the disc's along with wrong wheels, when disc's were installed.
Maybe in time, when more info surfaces, they will do it again.
The kits are easy to install, as many have already done.
But, any owner can do it without Airstream's assistance.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-15-2009, 08:45 PM   #9
Halimer
Profile:  2006 25' Classic
New Hyde Park , New York
Andy,
Is there something inherently wrong with the disc brakes and wheels that came installed the previous models?
Mark
halimer is offline   Reply With Quote
Old 10-15-2009, 09:17 PM   #10
Commercial Vendor
Originally Posted by halimer View Post
Andy,
Mark
No.
It was a matter of that didn't work with this, and this didn't work with that, and that didn't work with that, and this didn't work with this.
Frustrating and costly.
Perhaps more part to part matching should have been done from the get go.
Oh well, it's not the first time that Airstream discarded a project.
Maybe again someday, but in the meantime, I am going to see if we can come up with perhaps a better deal.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-15-2009, 09:14 PM   #11
Astroboy's Avatar
Profile:  2007 28' International CCD
West Hollywood , California
I find the superior braking performance of disc-brake system attractive...
That having said, I see 2 (minor) disadvantages.
1) I have to make space for the actuator, meaning I need to give up some storage space from interior (probably under the front gaucho?)
2) I need to change and bleed the brake fluid (nasty!) every few years. I have to find a way to pump out the old fluid and also bleed out from all (2/4/6) calipers.
With regular elecro-magnetic drum brakes, the maintenance is much easier and quicker: 1. wirebrush off crud/dirt, 2. check/adjust shoe clearance, 3. check/swap return springs.
Astroboy is offline   Reply With Quote
Old 10-15-2009, 10:04 PM   #12
Commercial Vendor
Surely you could afford to give up the space of a loaf of bread.
We encourage owners to install the actuator in one of the access compartments, and not under the front window, whenever possible. And there are other places as well, such as under the closet false floor, under the galley cabinet, under a bed, etc.
The actuator can be placed in many different places, and the closer to the axles, the better, as the amount of steel tubing is then minimized.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-15-2009, 10:23 PM   #13
2airishuman's Avatar
Profile:
DON'T bee confused..
unfortunately THIS sort of info is miss-inform-ing.
the factory service center STILL installs and services disc brakes
they have packages for 1 or 2 or 3 axle trailers.
with or withOUT axle upgrades.
your current wheels may or may NOT fit over discs, nothing about this issue has changed.
____________________
discs were OPTIONAL on classic models in early 2005,
then became STANDARD on classics from late 05 through last year.
MOST of the classic models have been DISCONTINUED, so
the LINE was only using discs on 1-5 trailers per month, or LESS.
_____________________
there is NO evidence that one cannot still order this as an OPTION on a new classic...
and even IF that's not possible ANY a/s dealer can do the disc upgrade...
along with the FACTORY SERVICE CENTER in jackson center...
no need to panic folks.
and try to understand the difference between adverts and info.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 10-15-2009, 10:45 PM   #14
Commercial Vendor
Wonder why so many "vendors" quit posting?
Could it maybe be that their intended informative post was hijacked?
Andy Rogozinski
Inland RV Center
Corona, CA
Disc Brakes Inland RV Center, In The Vendor's Forum 12 07-05-2009 09:14 PM
disc brakes nursematt 2007 Classic (all lengths) 9 01-27-2009 09:51 PM
Disc brakes. Inland RV Center, In Brakes & Brake Controllers 23 06-28-2005 07:37 AM
disc brakes overlander Brakes & Brake Controllers 10 01-26-2003 12:29 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 08:56 PM
