Go Back   Airstream Forums > Airstream Marketplace > The Vendor's Forum
Old 10-15-2009, 11:14 PM   #1
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
The subject matter is not wandering. I personally don't see the hijack.
Originally Posted by 2airishuman View Post
the factory service center STILL installs and services disc brakes
they have packages for 1 or 2 or 3 axle trailers.
with or withOUT axle upgrades.
your current wheels may or may NOT fit over discs, nothing about this issue has changed.
Inland has a wide service area. But 2air's post goes to the point -- that for the broad 50 states (and more), check your nearby Airstream dealer too.
Old 10-16-2009, 10:42 AM   #2
Commercial Vendor
Profile:  Corona , California
unfortunately THIS sort of info is miss-inform-ing.
I believe I stated that "PRODUCTION" will no longer install disc brakes.
I can't see how that's misinforming, at least to most people.
Service will do most anything, for a price.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-16-2009, 10:54 AM   #3
serial airstreamist
wheel interested's Avatar
Profile:  2005 28' Classic
Lapeer , Michigan
Images: 117
I think I misunderstood in my initial post. In my mind I was just thinking the factory and service is all one in the same and not putting disc brakes on any production Airstreams meant any or all Airstreams produced. I don't quite have the whole picture and the Airstream-Speak down pat.
Sorry Andy. Thanks for clearing up that my disc brakes are not a safety risk. I was also worried about that that might have been a reason Airstream stopped installing them.
But I bet it is more along the lines of few units having them installed and diminishing returns on the line expertise and cost cutting measures as 2Air pointed out. I thought those were good points too.
CJ
The future belongs to those who believe in the beauty of their dreams.-Eleanor Roosevelt
It is never too late to be who you might have been.-George Eliot
wheel interested is offline   Reply With Quote
Old 10-16-2009, 03:43 AM   #4
Astroboy's Avatar
Profile:  2007 28' International CCD
West Hollywood , California
I found a nice bracket, which would possibly let me mount the actuator below the floor-board level (perhaps under the closet in mid-corridor, or perhaps perhaps maybe under the shower pan?).
- Mounts easily on the side of frame rails with U-bolts
- Dimensions: 15.15” x 6.0” x 4.0”
(http://www.carlislebrake.com/pdfs/bracketsheet.pdf)
BTW & FYI, the testing shows of typical 1-second delay for the disc brake to pressurize and engage..., is it possible electro-magnetic drums do engage quicker (almost at the speed of light?)
Say, I notice something in front of me. Say, it takes typically 0.2 sec for me to step-on the pedal. Another additional 1-sec delay for the actuator to pressurize means the total of 1.2 sec; it seems awfully too long (?!)
Response Time Test Results::Carlisle Industrial Brake and Friction
Astroboy is offline   Reply With Quote
Old 10-16-2009, 04:36 AM   #5
WK57ABF's Avatar
Profile:  2007 25' Classic
kendal , cumbria, UK
Andy,
We're on our fourth Actibrake actuator and want to purchase a 'spare' for when the current actuator fails.
You fit the Carlisle unit - I've looked at this and it is only 1/2" shorter than the box in which the Actibrake unit is housed.
Is this why you fit the Carlisle unit in some other location?
John in the UK
WK57ABF is offline   Reply With Quote
Old 10-16-2009, 09:04 AM   #6
Commercial Vendor
Originally Posted by WK57ABF View Post
Andy,
John in the UK
John.
Perhaps things are different in the UK.
In America today, what belongs to you, might suddenly belong to another person.
That being said, mounting a disc brake actuator, in plain sight, or even in a box on the A frame, can easily be tempting to be stolen, by someone who also wants disc brakes "on the cheap".
In our usually beautiful country, people steal highway guard rails, underground community wiring, central air conditioners, and many other things as well.
Installing an "actuator" within the trailer, does 2 things. First, it's out of sight and second, it's out of the weather.
Installing it properly, in an access compartment, does not restrict the ability to service it, when necessary.
I have made these statements, knowing full well, that someone, much higher in life than me, will probably criticize and throw rocks at those reasons.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-15-2009, 11:36 PM   #7
2airishuman's Avatar
Profile:
Originally Posted by Astroboy View Post
I find the superior braking performance of disc-brake system attractive...
That having said, I see 2 (minor) disadvantages.
1) I have to make space for the actuator, meaning I need to give up some storage space from interior (probably under the front gaucho?)
2) I need to change and bleed the brake fluid (nasty!) every few years. I have to find a way to pump out the old fluid and also bleed out from all (2/4/6) calipers...
imo these 2 issues are WORTH it IF u tow much or drive in the mountains.
-i got 50,000 miles on the first set of brake pads and even then they were at 90% of the oem depth when changed.
-the actuator on my 34 is UP FRONT and works great in that location.
the tongue of a 34 is about as LONG as any line running and again works fine.
-i think OUTSIDE is a better location for the fluid reservoir because of maintenance issues.
do any cars have the master cylinder IN the passenger compartment?
-and bleeding is EASY because the reservoir is SO BIG...
one may attach a (lisle) FUNNEL designed for brake fluid changes on TOP as well.
with a vacuum gauge or "power bleeder" it becomes a one person job to do the fluid.
just use a DIFFERENT COLOR fluid every other time, and watch for the color change at the bleeder nut.
-and it is SO MUCH easier to inspect the pads and brake parts WITHOUT needing to pop open a hub.
still LOTS of folks love their drum brakes and do fine with them.
but i really really like the discs.
honestly with a/s production a ONE (or 2) classics a month, i'm not sure the guys on the line get enough practice now.
MY preference would be to roll the trailer over to the service shop and have dave's boys to the work...
the wheel compatibility issue was SOLVED in 2006, that's old news.
yes actibrake is OUT OF BUSINESS but other actuators are available.
and while I LIKE the kodiak stuff on my unit DEXTER also makes disc components...
in fact the ASSEMBLY LINE has been using dexter since 06, while the SERVICE center uses kodiak stuff.
with the calls about "oh my oh my actibrake" and the PRESSURE TO PRICE them better,
it's no surprise the disc trial only lasted 4 years.
the BIG question is this...
IS a/s gonna LOWER the price on classics NOW????
the disc upgrade was 4-5k originally, so it would seem PRICES should come down to refect that...
wanna bet they don't??
always keep yer eYe on the ball and cups and shify fast hands (or keyboard)
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 10-16-2009, 12:34 AM   #8
Profile:  2007 25' Safari FB SE
Juniper Hills , The Great Mojave Desert
With regular elecro-magnetic drum brakes, the maintenance is much easier and quicker: 1. wirebrush off crud/dirt, 2. check/adjust shoe clearance, 3. check/swap return springs.
I stuck the brake unit in one of my Airstreams misshaped not very useful anyway cabinets that happened to be over a wheel well. Simple, easy and out of the way.
Replacing brake fluid is so easy with the hand vacuum pump system. Just hook it up to the bleeder and drain away and refill.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is online now   Reply With Quote
Old 10-16-2009, 08:23 AM   #9
Minno's Avatar
Profile:  1972 31' Sovereign
Lexington , Minnesota
Andy,
I also have some questions.
1. Will the disk brake system work on any brand replacement axel?
2. Is the controller in the TV the same one used for electric brakes, or is there a different one needed?
2a. If the controller is different, does it come as part of the package?
3. Will the disk brakes fit inside the replacment wheels you sell (p/n 11147)?
Chris
Old 10-16-2009, 09:15 AM   #10
Commercial Vendor
Originally Posted by Minno View Post
Andy,
Chris
Chris.
1. Yes, but 12 inch disc brakes cannot be installed in place of 10 inch electric brakes.
2. Most electric brake controllers work equally well with disc brakes.
2a. I am not aware of anyone providing a controller, as part of a disc brake kit. It does not come with our package.
3. Absolutely, even if someone also adds the Centramatic balancers.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-16-2009, 09:23 AM   #11
Minno's Avatar
So, when I go to buy new axels next year, and I want to change to disk brakes instead of electric brakes, I would order axels without any brakes at all, right? And this kit would work on my 72 Sovereign?
Thanks - I was wondering about using the Centramatic balancers as well, but I forgot to ask that.
Chris
Old 10-16-2009, 10:04 AM   #12
WK57ABF's Avatar
Andy,
Thanks for response. Things are no different in the UK. But, out of 60 million people I think there's only me that knows what a brake actuator is and what it does (don't know of another Classic with disc brakes in the country), and also being full timers we are always around, so theft isn't an issue.
So, when our fourth Actibrake actuator fails, I'll have to fit a Dexter unit because the Carlisle unit won't fit in the A frame box.
John in the UK
Old 10-16-2009, 01:00 PM   #13
w7ts's Avatar
Profile:  2010 31' Classic
Longmont , Colorado
I don't know about the rest of the product line, but these are what came factory installed on my 2010 Classic 31.
http://dexteraxle.com/i/u/1080235/f/...djust_4-09.pdf
regards,
Ken
w7ts is offline   Reply With Quote
Old 10-17-2009, 11:54 PM   #14
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Not concerned.
Hi, I have been all over the western side of this country several times and on this last trip spent most of the day crossing the rockies in Colorado. My drum brakes are more than enough to stop my trailer. I went down many steep mountains and barely ever used my brakes; I just manually down shifted my Lincoln and enjoyed the brake-less ride down all of the mountains. I turned my brake controller down when on ice and back up when in traffic. They may have less power and fade quicker, if not used properly, but they always work. In over five years, I have not experienced any brake fade or failure. No trailer discs for me. When they make trailer discs that work as well, and are as dependable as the ones on my Lincoln, I'll think about it. [MY OPINION]
Name:	IMG_1250 (Large).JPG
ID:	89197   Click image for larger version
Name:	IMG_1271 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Disc Brakes Inland RV Center, In The Vendor's Forum 12 07-05-2009 09:14 PM
disc brakes nursematt 2007 Classic (all lengths) 9 01-27-2009 09:51 PM
Disc brakes. Inland RV Center, In Brakes & Brake Controllers 23 06-28-2005 07:37 AM
disc brakes overlander Brakes & Brake Controllers 10 01-26-2003 12:29 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 08:56 PM
