Go Back   Airstream Forums > Airstream Marketplace > The Vendor's Forum
Old 10-28-2004, 07:55 PM   #43
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Well Tom, those of us who don't live where the earth is flat until you fall off may have a need for brakes that are more fade resistant. I for one will be putting new axels on my 59 overlander and will be doing dual axels with brakes all around. We it be over kill. Prehaps, but that's better than being killed going down the other side of getting up the mountain. You seem to be having a personal issue with this and need the last word. I compliment Andy on his effrots to bring us the option of disc brakes. I may get them from him or from a local guy who can do Dexter I don't understand what you are so tight about. If you are happy be happy.
Let those who can play, let those who cann't rule.
Over59 is offline   Reply With Quote
Old 10-28-2004, 10:28 PM   #44
markdoane
Profile:  , Minnesota
Images: 59
I'm a little concerned about possible failure modes, and the 0.8 second delay for the hydraulic pump. With automotive electronic disc brakes supposedly available in a year or two, I think I'll wait.
People have been going down the other side of the mountain for years with electric brakes. Yeah, some of them have problems. I think situational awareness and knowing your trailer and tow vehicle's braking capability are more important than what type of brakes you have.
Non-contributing deadbeat.
markdoane is online now   Reply With Quote
Old 10-29-2004, 06:17 AM   #45
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
i want air brakes! with anti lock!
blue hose red hose, how hard can it be?
john
you call them ferrets, i call them weasels.
Old 10-29-2004, 11:34 AM   #46
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Markdoane.
There is not an .8 second pump delay.
There is a .8 second rise time to obtain maximum 1400 PSI.
That, is pretty fast.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 10-29-2004, 02:14 PM   #47
markdoane
Images: 59
Oops! I was wrong. Thank you for the correction.
Old 10-29-2004, 05:17 PM   #48
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Exclamation Please let us know...
Andy,
Please let us know when the information gets posted to your website...I have a project coming up that the disc brakes along with new axles maybe the answer too
Aaron
WBCCI #2449 AIR #2495
Old 10-29-2004, 05:22 PM   #49
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
So if my new axels are going to have disc brakes I'll want to replace the current copper hydrolic line before I close in the belly and the floor? I can leave alot on both ends for the later installation. What gauge / type copper tubing should I use and is putting it between the floor and belly the way to go like the original tubing?
Old 10-29-2004, 05:53 PM   #50
Commercial Vendor
Over59
DO NOT USE COPPER TUBING FOR HYDRAULIC BRAKE LINES.
Copper will not take 1400 PSI, let alone any safety factor.
We will have the steel line kits available separately, if someone wishes.
Inlandrv.com
800-8777311
Old 10-29-2004, 06:01 PM   #51
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Ha Ha Ha! Copper brake lines! LOL!!! I never understood why my vaccuum hoses kept bursting when I tried to modify them to work with my brakes!
My double steel wall brake lines on my Olds finally failed (rusted and got soft) after 25 years of stopin' in the brakes and going through all the salt up here in winter. A soft metal like copper might not rust, but would last all of 5 minutes at that at the brake pressures we are talking about.
I totally agree with Andy....copper is a very bad choice for brake lines.
Old 01-28-2005, 08:12 AM   #52
Over59
Over59's Avatar
1968 17' Caravel
Images: 37
Glad I asked. Andy does get excited about safety. Thanks.
Old 01-28-2005, 10:21 AM   #53
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Andy, Trailer Life has just printed an interesting article on disc brakes installed on an older 5th wheel. It gave the braking distances both before and after. Has Airstream or anyone else to the best of your knowledge ever printed this data? I have always felt a little uneasy when the 18 wheelers pass and pull in 10' in front of me at interstate speeds, knowing that if they had to panic stop we would be come one.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 01-28-2005, 10:42 AM   #54
Commercial Vendor
Tarheel
Can you e-mail or fax me a copy of that article?
I am not aware of any stopping distance tests comparing electric brakes to disc brakes, run by any company.
However, we all know that disc brake systems are far superior to electric brakes and regular hydraulic brakes.
Perhaps Airstream might run those tests, since they will be offering disc brakes on some of the models.
Inlandrv.com
800-8777311
Old 01-28-2005, 04:26 PM   #55
Tarheel
Tarheel's Avatar
Images: 21
Andy, Sent an e-mail hope you can read it. I had to print it before I could.
WBCCI # 3485
Region 3 1stVP
Old 01-28-2005, 05:39 PM   #56
Commercial Vendor
Tarheel.
Thanks for the e-mail.
Unfortunately, it won't print so that you can read it.
I sent you an e-mail with a different request.
Thanks.
Inlandrv.com
800-8777311
Brake controller crapped out Chuck Brakes & Brake Controllers 5 06-21-2004 08:21 PM
Brake Seizure - Front Right Side josephhh Mechanics Corner - Engines, Transmission & More... 15 03-26-2004 11:15 AM
1977 airstream 31' beekman Off Topic Forum 6 03-01-2004 09:25 AM
Hensley Brake Controller $427 New markjoandall Brakes & Brake Controllers 2 11-19-2003 07:47 AM
Brake Horror Story Mike76251 Brakes & Brake Controllers 4 10-06-2003 12:41 PM
