I also forgot to mention that the tag is Airbrushed and is not a sticker.These are made up from yours truly so each one done is never the same even though they are very close to looking the same and pretty much exactly alike.
Devoman: We're relatively new to "Airstreaming". In an earlier post you mentioned "static cling" as a method for applying numbers to our trailer. How did the 7 mil work out? We are going to international at the end of the month (we're international vergins) and need to get numbers on the trailer, but I'm not sure I want to put them there permanently! Looking for a quick and easy solution, any suggestions?
For those of you that have emailer me about the cling on.I have some coming and should be here by tues at the latest.this is same material that is used for signage and many other applications.also these are an 8 mil thickness.thanks everyone.
Clear 8 mil Cling-on.
• A clear, flexible static cling vinyl
• Clings to most clean, dry, highly polished smooth surfaces without adhesive
• Ideal for window displays, point of purchase decals, seasonal decals, oil change labels, price stickers and vehicle advertising
Man that looks Great!!!!!! Makes me want to get some #s
Originally Posted by moosetags
Here is living proof that WBCCI red numbers and AIR blue numbers can coexist on the same Airstream. I think that they look good together. If a person wanted to really make a statement, he could have large blue AIR numbers on top with small red WBCCI numbers below. That would cause some talk at the International in Perry.
Custom made License plates.All you will need is a high res photo and I can set you up with putting it on a car tag.Customize it with your own words.
E-mail me for quotes.Thanks Everyone.
