Old 11-17-2009, 02:15 PM   #1
BRAKES, BRAKES and more BRAKES
We just completed a huge special purchase of 12 inch backing plates, that allows us to substancially reduce the selling prices.
12 inch electric brake backing plates, were $79.00, now $45.95 each.
12 inch electric brake backing plates, self adjusting were $89.00, now $49.95 each.
Old 11-17-2009, 03:14 PM   #2
wolverine's Avatar
2005 31' Classic
Sunrise Beach , Missouri
If anyone has been considering upgrading your brakes to self-adjusting drum brakes, this is the time to consider this great deal. I just upgraded mine last month and it is a fairly simple job (it was my first time). If you need to inspect and repack your wheel bearings, this should all be done at the same time. You'll need to replace the grease seals to do the job right and I'm quite sure that Andy can include these with your order.
wolverine is offline   Reply With Quote
Old 11-17-2009, 03:21 PM   #3
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Shelf Life
Hey Andy,
Sounds like a great price, unfortunately I rebuilt all my brake assemblies last year. However, at this price it may be worth the purchase for future repair. Is there a shelf life for these units?
fltlevel510 is offline   Reply With Quote
Old 11-17-2009, 03:25 PM   #4
Originally Posted by fltlevel510 View Post
Hey Andy,
Either your a pilot, a crew member, or on some real good stuff.
Shelf life is unlimited, as long as you keep them out of the weather.
There is nothing to age, at least during the first 100 years.
After that, no promises.
Old 11-17-2009, 04:47 PM   #5
Airstream01's Avatar
2008 25' Safari FB SE
Land of fruits and nuts , California
What size brakes do I currently have on my '08 Safari SE 25FB? I do have Dexter axles, serial # 121537515 w/ 3800lb rating.
If I indeed have the 12"ers, what all is needed to convert to self adjusting besides the backing plates? Thanks Andy
Edit: typically I would just run out and measure for myself, but my mobility is severely restricted after I got creamed at my last motorcycle race and put a new joint in my right tib/fib. Thanks for any and all assistance.
Airstream01 is offline   Reply With Quote
Old 11-17-2009, 05:30 PM   #6
We do not have any records of Dexter axle serial numbers.
Your Airstream, according to our information, has 12 inch brakes.
There is nothing you need to do to install the "self adjusters" except to remove the old backing plates and install the new.
Obviously the hub and drum must be removed to do that.
You can make the change by pulling one axle up on some 2 x 6's, which will elevate the other axles tires off the ground. After you change out the backing plates, reverse the process with the other axle. No jacks needed.
Old 11-17-2009, 06:47 PM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
94 Sovereign
Andy....I have 10 inch brakes and the Airstream aluminum wheels will these 12 inchers be able to be used with these wheels.??? (94 Sovereign)
Old 11-17-2009, 06:56 PM   #8
Unfortunately, 12 inch brakes cannot be installed in place of the 10 inch brakes.
Probably the easiest way you could accomplish that would be to change the axle.
Brakes Inland RV Center, In Brakes & Brake Controllers 27 03-03-2010 09:36 PM
Brakes hskingdon Brakes & Brake Controllers 2 05-25-2009 12:27 PM
Brakes-Have tried most everything. bluegrass-girl Brakes & Brake Controllers 21 07-18-2008 06:20 PM
Do I need brakes? Jephellis Brakes & Brake Controllers 7 07-09-2008 11:08 AM
No Brakes IndyCutter Mechanics Corner - Engines, Transmission & More... 6 01-21-2006 07:43 AM
