Go Back   Airstream Forums > Airstream Marketplace > Commercial Listings
Old 09-21-2013, 09:02 PM   #261
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by Steamy1 View Post
if you add spacers, then is there the possibility that the rack is out of alignment? The instructions does not say anything about grinding, but it does not say anything about spacer bolts either.
Hi, you might have seen in the video that the tubes will need to be flexed a bit to align with the mounting brackets. So a little outward flexing shouldn't hurt anything. I would do it.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 10-24-2013, 11:25 PM   #262
interstateflyer's Avatar
2017 25' International
Los Osos , California
I installed an Airstream/Fiamma rack on my International 19 last week. It went pretty smoothly.
You'll need to buy 4 #10 stainless steel screws, #30 and 1/4" drill bits, anticorrosion compound (for the screws) and watch the Airstream install video on YouTube. You'll have to fill in the blanks at time but it's a heck of a lot better than relying on the the printed instructions.
One large mountain bike fits nicely.......two....not so much.
Fiamma sells racks that support a wider spacing for the wheel channels. I'm looking into buying the deeper u shaped support piece that will allow more distance between bikes..
ID:	198685   Click image for larger version
Name:	side blurr.jpg
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 04-17-2014, 04:47 PM   #263
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
Originally Posted by Aage View Post
Until they offered the Fiamma rack, for many years Airstream warned that carrying things on the back of the trailer was NOT a good idea. Not sure why they changed their corporate mind after many years of warning against doing that, but they did.
However, when you say you are carrying 5 gallon jugs in the rear storage, I hope you mean empty ones, since each one weighs over 41 lbs filled. The effect of that weight is also magnified by the fact that it is behind the axle.
The "moment of the arm" affect of that water's weight can be devastating to your frame.
Note: if I am misunderstanding what it is you do with the jugs, please ignore these comments.
I agree. I like the idea, but somehow it makes me nervous. After dealing with what rear end separation can do, I am on the fence with this one.
GAStreamin is offline   Reply With Quote
Old 04-17-2014, 05:00 PM   #264
Pivot429's Avatar
2014 25' FB International
Dayton , Ohio
We put two 29er mountain bikes on ours and incredibly they only touch in one place. Really kind of unbelievable how they nest together. Try moving the rear tire to the end of the channel on both bikes.
Sent from my HTC One using Airstream Forums mobile app
ID:	209866   Click image for larger version
Pivot429 is offline   Reply With Quote
Old 04-23-2014, 08:38 PM   #265
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
Images: 20
Bike carriers
We finally broke down and bought the Swagman XP5 for our bikes... I am intending to use it as a received mount on the front of the truck rather than on the rear of the trailer. I'll take photos when I get it. I'm sure it will catch most of the highway bugs.
http://www.swagman.net/products/sing...xp-racks/xp-5/
Hibby
Hibby is offline   Reply With Quote
Old 04-30-2014, 03:44 PM   #266
loislane's Avatar
2014 23' International
Saint louis , Missouri
Hey All,
I just got a quote on having the fiamma rack installed on my 23ft - the dealer said it would take 6 hours of labor - does that sound right to you guys who have installed it? Also they said they'd only installed one other rack so I'm not that confident. Anyone near St. Louis have any recommendations for an installer? My husband may try it - its really time that is our issue.
Let me know,
Lois
LoisLane
2014 23d Int'l CCD
TV: Toyota 4runner
"Homer"
loislane is offline   Reply With Quote
Old 04-30-2014, 04:26 PM   #267
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Front Receiver and Hollywood HR1000
Reese/Drawtite front receiver - $159 from Amazon, 20 minute no-drill install
Hollywood HE-1000 2-bike rack - $249 from local bike shop. Very well made, strong and stable
I can also use the front receiver when parking the trailer in the driveway. Gonna get a wheel foot for the tongue jack to take some load off the front end.
Al
Old 05-01-2014, 05:05 AM   #268
matthorr's Avatar
2012 25' FB International
Colorado Springs , Colorado
It took me about 3 hours to install (including grinding a bit of the bumper storage lid to clear the bolt heads). It's pretty easy to do, I was taking it slow to make sure I drilled the holes correctly the first time. To get our 2 mountain bikes on there we moved the tires channels all the at to opposite sides - back one full left and front one full right. The bike then fit without hitting each other.
Sent from my HTC One X using Airstream Forums mobile app
matthorr is offline   Reply With Quote
Old 05-01-2014, 05:51 AM   #269
loislane's Avatar
Hey Matt - did you relocate the license plate? I watched the airstream video and they said you needed to do that but it seems a little overboard to us
LoisLane
2014 23d Int'l CCD
TV: Toyota 4runner
"Homer"
Old 05-04-2014, 09:44 PM   #270
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
This is probably a dumb questions, but what the heck. Would it be possible to mount a receiver hitch to the rear frame of the AS that could attach a receiver bike rack on the rear of the AS or could be moved to the receiver on the TV?
thanks, Al
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
Old 05-04-2014, 10:39 PM   #271
Originally Posted by loislane View Post
Hey All,
Let me know,
Lois
It took me around 3 hours. Most of the time was spend putting the tubes together. Drilling, bolting and screwing went pretty quickly. I would think that I could get it down to 2 or 2.5 if I hurried.
Old 05-04-2014, 10:41 PM   #272
Airstream had to say that. I wouldn't worry about that unless you get a fix it ticket.
Old 05-05-2014, 11:36 AM   #273
jpons's Avatar
2008 20' Safari SE
Bangor , Maine
The consensus is that this would put too much weight on the rear of the Airstream which could cause problems with the Airstream frame, chiefly rear sagging.
I think some people have done it, not sure what their results have been.
-J
thanks, Al
jpons is offline   Reply With Quote
Old 05-05-2014, 10:44 PM   #274
Eagle Creek , OR
Thanks Jpon... read through some other threads and see the logic of the motion and torque of the receiver hitch messing with the frame/body juncture. Seemed like a good idea in the abstract, but the forum wisdom makes better sense. Probably not that much more expensive for the "approved" rack spreading the stresses across the body and frame. Living in the AS full time, I've been holding off on bikes just because of the hassle of where to put them with living space and storage space at a premium without a home base. Pretty much everything we take does double duty in some respect. Collapsible bikes was one thought, but still a storage and security issue. Would be nice to have a double duty rack to use with the TV, but maybe just putting in the truck bed loose for a quick side trip will work as well.
Al & Robin
Old 05-06-2014, 06:32 AM   #275
matthorr's Avatar
No I didn't move the license frame. I haven't been pulled over (yet...). Fiamma sells a fabric bag cover for the bikes that holds a license plate and/or reflector (an Italian requirement) Bike Cover - Fiamma
Old 05-13-2014, 09:16 PM   #276
loislane's Avatar
Installation complete - thanks everyone!
Thanks to the help of folks on the forum Jim was able to install the bike rack with no problem in under three hours - NOT the six hours the dealer quoted us....
LoisLane
2014 23d Int'l CCD
TV: Toyota 4runner
"Homer"
Old 05-14-2014, 11:52 AM   #277
Has anyone tried the cover on an A/S?
I'm wondering if it obscures the tail lights at all. Seems like it would.
Old 10-13-2014, 12:01 AM   #278
TCwheels's Avatar
2019 25' International
Traverse City , Michigan
thanks, Al
Check out this setup from silverbp. He built a frame for the receiver and installed it under the bumper box. I'm doing the same thing. The CW doesn't seem to be supported with data from newer units and my FC20 doesn't have much frame length behind the axle.
Name:	ImageUploadedByAirstream Forums1413180031.739250.jpg
WBCCI #7246
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 11-24-2014, 10:17 AM   #279
2013 25' International
mont st hilaire , Quebec
hi I need to find a cover for my fiamma carry bike
do you have some ideal
'need to be strong winter seasohere
thank you
socool69 is offline   Reply With Quote
Old 02-08-2016, 08:55 AM   #280
Suzbp's Avatar
2013 25' Flying Cloud
Apopka , Florida
Lois I have appointment for install next week at a dealership that does installs all the time and they said the install time is approximately 2 to 2 1/2 hours. Sounds like your quote either doesn't do this often or is overcharging you!
Suzanne
Suzbp is offline   Reply With Quote
Bike carriers Inland RV Center, In Commercial Listings 280 08-01-2017 10:01 PM
Bike Racks airdan Exterior Restoration Forum 1 02-14-2012 02:30 PM
